Douglas Wong's Blog Creating a Maker Wish List
  • Author Author: dougw
  • Date Created: 19 Dec 2016 6:46 AM Date Created
  • Views 4123 views
  • Comments 26 comments
  • maker_wish_list
  • christmas_wish_list
  • wish_list
dougw
dougw
19 Dec 2016
For me accumulating a complete set of tools, software, instrumentation and stock to permit building electronics projects has been a long slow process (decades) and it is still going on. This list is my idea of the most effective order in which to acquire new equipment. It takes into account cost and usefulness. I did not exactly follow this path as costs were different when I started - back then a DVM was a very expensive device.
  1. 3.5 digit DVM (DVMs are the most used instruments and they are now low cost)
  2. hand tools (needle nose pliers, side cutters, wire strippers, xacto knife, tweezers, screwdrivers, nut drivers, metal shears, vice grips, hack saw, files)
  3. internet computer (information is the thing that will save you the most time and money)
  4. temperature controlled soldering station (if you do electronic assembly, you cannot get far without one of these)
  5. 5 volt power supply (it is important to have reliable bench power supplies - it will make troubleshooting a lot easier)
  6. stereoscopic microscope (or at least high magnification inspection goggles) electronics are shrinking all the time - it is hard to work effectively if you can't see what you are working on
  7. vice (a vice is a strong third hand that increases your abilities) (I have at least 4 on my bench)
  8. variable power supply (this is the second most used electronics instrument - if it displays voltage and current, it will be a lot more useful)
  9. electric hand drill (electronics need packaging and mechanical interfaces - most projects will need some drilling)
  10. RLC meter (a DVM does some of this and may be sufficient, but sometimes you need to measure these things - it can save a lot of effort)
  11. electronic CAD (the fastest way to design something is if you have it stored from the last time - a real time saver)
  12. oscilloscope (signals are mostly inyteresting when they are changing - and this is the best way to see what they are doing)
  13. drill press (if you want your projects to look good they need accurate mechanics - a drill press is the minimum to get started on accuracy)
  14. frequency generator (these simiulate the output of cicuits and sensors and can save a lot of effort)
  15. electric screwdriver (can save time)
  16. mechanical CAD (when you want your proects to be aesthetically pleasing and consistent and accurate and repeatable, you need CAD)
  17. 3D printer (the lowest cost way to build prototypes in many cases)
  18. hot air rework station (makes SMT work much easier)
By the time you have accumulated this much equipment, you will have enough projects under your belt to know what else you need. For example if you are into radio, there is a different set of equipment that is important than if you are into lighting, or audio, or robotics or IoT or wearables etc.
I have already accumulated more than what is in the above list so I have a fairly complete lab.
Now my wish list is more focused on new modules and parts I would like to embed in electronics projects.
Generally, it is not clear what parts will be needed in future products, but there are some platforms that I expect will be used sooner or later.
I definitely have a couple of Raspberry Pi 3 projects on my to-do list, so they are high on my wish list.
The PSoC Kits are very handy for projects that don't need quite so much horsepower.
And I can always use more 3D printer filament, or if that isn't available a load of Neopixels is bound to find a home sooner or later.
Specific products that are high on my wish list along with why:
Raspberry Pi 3 Model B (I still need one for my Pi IoT project, and I would like to build a Pi arcade system, and maybe an MQTT broker)
PSoC 5 CY8CKIT-059 (the PSoC Creator development environment makes this low-cost Cortex M3 system powerful and easy to use)
PSoC 4  CY8CKIT-043CY8CKIT-043 (likewise the PSoC Creator development environment makes this low-cost Cortex M0 system powerful and super easy to use)
Robox Filament  RBX-PLA-WH170RBX-PLA-WH170 (I am continuously amazed at how many uses I find for my 3D printer - it changes the way I think about a lot of things)
  • Workshopshed
    Workshopshed over 9 years ago in reply to COMPACT +3
    I started a bit later than Compact but had a tiny soldering iron, some side cutters, a scalpel and some pliers. Only recently got a temperature controlled iron and that was one of the best investments…
  • Workshopshed
    Workshopshed over 9 years ago in reply to rachaelp +3
    Ah yes, a desoldering tool. I used a little rubber ball type and braid for years, got one of those spring loaded ones a few years back.
  • Workshopshed
    You probably also avoid the blow torch approach then...
    Jan Cumps over 9 years ago in reply to COMPACT
    There may be a niche market for Oculus or Technical Illusions VR glasses?
    They could, helped by cameras that film the board, give a 3d enhanced view of the part you're looking at.
    And combined with shabaz' pick'n'place, they could also highlite the position of the 'next part to solder'. Both on the pcb and in the parts tray image.
    ... Runs to the patent registration bureau. Ow. Closed on xmas eve.
  • rachaelp
    rachaelp over 9 years ago in reply to dougw
    Douglas Wong wrote:
    My only recommendations are:
    1. try the optics before you buy - some are quite tricky to get a good view of the subject and your eyeballs need to be within microns of some magic optimal position
    2. try to implement a mounting arrangement that allows maximum room under the viewing head.
    Thanks for the suggestions, very helpful image
    I'm currently looking at possibly something from the AmScope range which do look really nice. I'd get one of the dual boom mounted ones so it's easy to position and gives plenty of free area under the head. I've found a few reviews which seem generally positive albeit with a few niggles. Here is one of the more in depth ones: http://technitoys.com/review-amscope-trinocular-boom-stereo-microscope/
    The next challenge is to work out which one of the many options is best and where to get it from in the UK at a good price. So far I've only found them on Amazon but the advantage there is Amazon has a great returns policy and if it doesn't work well its easy to send back for a full refund.
    dougw over 9 years ago in reply to COMPACT
    It may be possible, but it is a tough to beat direct optics. I once built a spectacular stereo microscope and camera system (ultra expensive) to help solve credit card fraud. It was a very successful system, but the photographs were never as good as directly looking through the stereo microscope. The direct view was fully 3-D.
  • COMPACT
    COMPACT over 9 years ago in reply to dougw
    I was going to get an all singing all dancing Vision Engineering Mantis Eyepieceless Stereo microscope but after demoing it I was very disappointed with its very shallow depth of field.
    I think the next generation of rework microscopes will be digitally controlled cameras that'll have a really deep depth of field (and be eyepieceless (via a flat screen monitor)).
  • Workshopshed
    Workshopshed over 9 years ago in reply to dougw
    I hope to build some kind of microscope next year but it won't be stereo.
