Douglas Wong's Blog Who remembers EPROM?
  • Author Author: dougw
  • Date Created: 21 Oct 2021 5:34 AM Date Created
  • Views 6240 views
  • Comments 12 comments
  • doug wong
  • eprom
  • zynq mpsoc
  • raspberry pi hq camera microscope
  • 27512
dougw
dougw
21 Oct 2021
This is just an off the wall way to say thank you to element14 and Xilinx. They had a little give-away draw to win a Zynq book and they ended up sending me a huge book called Exploring Zynq MPSoC and a screw driver set. I also recently completed a Project14 so I threw in some images from that project.
This is a digital microscope image of a 27512 EPROM. It took a lot of digging in my archives to find this chip, but I wanted a chip with a ready-made window so the microscope could image the actual silicon.
Click on the image for a full size view.
Here is what a typical EPROM looks like with its window to allow UV light to erase the memory:
I also took a a closer image just to see what this microscope can do....
I'm having a lot of fun with this microscope.
Here is a video of the FPGA Technology Quiz prizes and the Pi HQ Camera microscope in action....
I once used EPROM without a CPU as a look up table to convert 18 bit gray code to binary.
Have you ever tried to use sunlight to erase an EPROM?
Feel free to add your EPROM stories below, I'm sure there are lots of them.
Relevant Links:
I Spy With My Digital Eye .... a Pico PI
    DAB over 5 years ago
    I started with the 2704 versions with only 4 K bits.
    They were so sensitive to electrostatic discharge.
    I could usually destroy one by just walking across the floor and picking one up.
    dougw over 5 years ago in reply to DAB
    It was a great improvement when 2716's got rid of the negative voltage and the 12V requirement and just needed +5V to run (the programming voltage was only needed at programming time, which was almost never in-circuit programming).
    DAB over 5 years ago in reply to dougw
    Oh yes, I had forgotten those issues.
    The simpler programming was very useful, especially when you were making a lot of changes and needed to burn new EPROMs daily.
