Gough Lui's Blog Click MR16 LED Globe Failure Post-Mortem
  • Author Author: Gough Lui
  • Date Created: 1 Jun 2016 5:59 AM Date Created
  • Views 3085 views
  • Comments 20 comments
  • fail
  • analysis
  • lighting
  • failure
  • led
  • led lighting
  • teardown
Gough Lui
Gough Lui
1 Jun 2016
One of my regular blog readers submitted an LED globe for post-mortem analysis, having failed well before the expected lifetime. I take a look inside, determine the configuration and analyze the relatively "anonymous" product which seems to show several design shortcomings which I discuss and think might be relevant to other readers at the element14 community.
The article is posted at http://goughlui.com/2016/06/01/failed-click-ltmr5w3k-5w-led-mr16-replacement-globe/
What really gets me is that many products are still designed using multiple-parallel LEDs without any current balancing mechanisms (e.g. remember emitter feedback resistors when paralleling BJTs?) and that leads to potential for a single string to be overstressed continually, fail early, and begin the cascade of failure as other LEDs are forced to soak up current in excess of their ratings, and operate in less efficient regimes resulting in greater heat production and degradation of the semiconductor material. Of course, if you went all-series, you would have an all or nothing situation and require higher voltage driver electronics, but I personally would gravitate to this arrangement for reliability reasons, or go with multiple independent channels if reliability is demanded.
Any comments, or stories related to LED globes or LED light designs are very much welcome.
- Gough
  • Dudley
    Dudley over 10 years ago in reply to Gough Lui +3
    We have absolutely no problem with you or anyone else posting links to blogs on external sites, as long as: It's of interest to engineers It's not spam Obviously we'd rather you blogged here, but we're…
    jw0752 over 10 years ago in reply to shabaz +3
    Over the years I have become used to working under (4) 150 Watt incandescent flood lights. Yes they were hot and probably cost a couple $ a month to operate but I needed to see the cracks and problems…
    jw0752 over 10 years ago +2
    Hi Gough, I am hoping that they do as good of a job figuring out what went wrong with me when I stop ticking as you performed on the LED globe. This is a great learning experience to follow your dis-assembly…
    mcb1 over 10 years ago
    Nice breakdown of the fault.
    Unfortunately LED technology is rather pricey and the alternatives like this give the consumer a bad taste.
    I still believe the LED lamps for domestic use have a long way to go before they are equal to what they are replacing in most applications.
    The biggest waste was downlights which were designed to not throw light across the ceiling and show the lower quality finish.
    Unfortunately it requires twice as many lights, hence is a power waster.
    I think your links are fine as the item is not an element14 sold product.
  • Gough Lui
    Gough Lui over 10 years ago in reply to mcb1
    Yeah, I never really understood the whole fascination with downlights. The old halogens were rated for something like 36 degree or 60 degree beam spread and really were more suited for spot and accent lighting, and somehow it became vogue to light up a whole room with 10-20 of them - at a lot of installation effort, I might add. All that heat ... and all that wasted energy. I'm sure some electricians probably earned a good living putting them in image.
    - Gough
    mcb1 over 10 years ago in reply to Gough Lui
    I used halogens in my house, and regret the five or six downlights I used.
    Good planning allows the use of minimal lights and in our case we have two 10 deg ones on in the lounge at 50w each, with two 36 deg in the kitchen at 50w, and three 35w in the hall on a dimmer.
    In all most nights we use 290-300w of light total.
    I'm sure some electricians did make good money, and sadly many consumers still buy the cheap lamps and wonder why they don't last ... like the LED one.
    I use either Phillips or Osram lamps and would be lucky if I replace 1 per year (total 33)
    As you can see I'm in no hurry to change to LED.
    mark
    mark
