Gough Lui's Blog Click MR16 LED Globe Failure Post-Mortem
  • Author Author: Gough Lui
  • Date Created: 1 Jun 2016 5:59 AM Date Created
  • Views 3066 views
  • Comments 20 comments
  • fail
  • analysis
  • lighting
  • failure
  • led
  • led lighting
  • teardown
Gough Lui
Gough Lui
1 Jun 2016
One of my regular blog readers submitted an LED globe for post-mortem analysis, having failed well before the expected lifetime. I take a look inside, determine the configuration and analyze the relatively "anonymous" product which seems to show several design shortcomings which I discuss and think might be relevant to other readers at the element14 community.
The article is posted at http://goughlui.com/2016/06/01/failed-click-ltmr5w3k-5w-led-mr16-replacement-globe/
What really gets me is that many products are still designed using multiple-parallel LEDs without any current balancing mechanisms (e.g. remember emitter feedback resistors when paralleling BJTs?) and that leads to potential for a single string to be overstressed continually, fail early, and begin the cascade of failure as other LEDs are forced to soak up current in excess of their ratings, and operate in less efficient regimes resulting in greater heat production and degradation of the semiconductor material. Of course, if you went all-series, you would have an all or nothing situation and require higher voltage driver electronics, but I personally would gravitate to this arrangement for reliability reasons, or go with multiple independent channels if reliability is demanded.
Any comments, or stories related to LED globes or LED light designs are very much welcome.
- Gough
  • Dudley
    Dudley over 10 years ago in reply to Gough Lui +3
    We have absolutely no problem with you or anyone else posting links to blogs on external sites, as long as: It's of interest to engineers It's not spam Obviously we'd rather you blogged here, but we're…
    jw0752 over 10 years ago in reply to shabaz +3
    Over the years I have become used to working under (4) 150 Watt incandescent flood lights. Yes they were hot and probably cost a couple $ a month to operate but I needed to see the cracks and problems…
    jw0752 over 10 years ago +2
    Hi Gough, I am hoping that they do as good of a job figuring out what went wrong with me when I stop ticking as you performed on the LED globe. This is a great learning experience to follow your dis-assembly…
    shabaz over 10 years ago
    We should have a section at element 14 for discussing different lighting product experiences and feedback. Although a lot of home lighting experience could be subjective though, so hard to compare.
    Much like mcb1 I too am in no hurry to swap conventional lighting at home for LED. But kind-of giving LEDs a trial currently in one room. The previous lights were incandescent, 40W or 60W (depending on what is available off-the-shelf - the 60W are getting rare in the DIY stores) x 5 lamps, which reflect off walls, not down spotlights.
    I went for these ones, the R50 version in the photo below: RefLED Blown Reflector | Sylvania Lighting Solutions
    These ones are not perfect for all rooms, they are not suitable for dimming with an incandescent lamp dimmer.
    The feedback so far is semi-neutral to positive depending on who I speak to.
    The consensus is basically it is definitely brighter. Those who are neutral overall say the color feels too white/unnatural, and the color or effect (could be CRI related or color temperature related, I can't decide) has a slight feel of ugliness like some economy CFLs have. I can see that too.
    I get the feeling that without mixing LED colors*, this problem would be hard to get rid of. I'm not sure though, and will try some more lamps.
    I might also swap back to incandescent for a bit, and see what the feedback is then..
    * maybe separate color lamps, e.g. dimmable red, to mix with white LED lamps could be an option too, to try to correct things. More awkward though.
    mcb1 over 10 years ago in reply to shabaz
    All the LED lamps I saw in AUS were warm colour.
    many were of the 60 or more degrees, which makes them useless for task lighting over benches, etc.
    So England is the right place to test these, NZ and AUS have sunlight ...  image
    I do have a couple of places to fit LED, but in talking to the electrical supplier there seems to be no direct replacements for my Dicrohics .... yet.
  • Gough Lui
    Gough Lui over 10 years ago in reply to mcb1
    We get either warm white (2700k most brands, 3000k for Philips) or daylight (6500k but only select sizes of Philips and Osram). On the whole, most people seem to prefer warm white inside, so I suspect the stockists don't stock the other lines for the most part - any other CCTs, you're going to have to go with some smart globe.
    While the LEDs are bright, many report that the latest high-efficiency units have a steep initial lumen depreciation, so they will be impressive when first turned on, but after the first few hundred hours, they will "do most of their degradation" and sit close to 80-90% of the initial output for the remainder until failure.
    - Gough
  • Gough Lui
    - Gough
