Gough Lui's Blog Woefully Insecure: Remote Control 433Mhz Power Sockets
  • Author Author: Gough Lui
  • Date Created: 10 Apr 2016 3:04 AM Date Created
  • Views 2621 views
  • Comments 15 comments
  • 433.92mhz
  • remote control
  • wireless
  • power switch
  • 433
  • remote
Gough Lui
Gough Lui
10 Apr 2016
It's been a while since I've had the time to post anything around here. Luckily, I had recently just submitted my PhD thesis so that gives me a chance to take a short break and do some of the stuff that I like.
Recently, I came across a bunch of cheap remote controlled 433Mhz power sockets which I decided to pick up, tear down and reverse engineer on my blog site. Because of the recent discussions regarding remote control that I've been a part of on this forum, I thought it would be rather interesting to some of the people here as well. What I found was most intriguing - a fixed code system with no checksum/CRC, a 3-bit address space and 1-bit switch command for 4 variable bits in a 25-bit message, and hard coded broadcast-to-all switches including fresh un-learned switches out of the box.
I think it's probably worth a read as I go through the whole process from start to finish, and now I have an Ethernet bridge to the 433Mhz system built out of my efforts. It doesn't improve security, but it does improve usability. However, it's a key point that even if a system has a "learning" button and doesn't seem to respond to "other" codes that it's not necessarily secure by design. It may just give the impression of security.
  • Gough Lui
    Gough Lui over 10 years ago in reply to clem57 +2
    Thanks for the comment clem57 . When I looked at the wholesale listings on made-in-china.com , they claimed that they do export market to USA, which I suppose means that they do have US-standard plug versions…
    shabaz over 10 years ago +2
    Hi Gough! Great post and relevant information. To be honest most consumer remote power strips are insecure here too. Although the ones I have seen have been built to a higher quality and using more reliable…
  • Gough Lui
    Gough Lui over 10 years ago in reply to shabaz +2
    Agreed on your views there shabaz , although I'd have to say that given the cost of rolling code "replacement" remotes for garage doors from China not being much, the cost of using a rolling code chip…
  • clem57
    clem57 over 10 years ago
    Long read, but a great learning about hacking that you went through. Do they make these in US standard plugs?
    Clem
  • Gough Lui
    Thanks for the comment clem57.
    When I looked at the wholesale listings on made-in-china.com, they claimed that they do export market to USA, which I suppose means that they do have US-standard plug versions as well. They no longer list any IR+RF units on their profiles, so I suspect this unit is now considered obsoleted, but the PCB marking code of SK-5808 still has ties with the RF remote versions. Local sellers here in AU won't ever stock these, but there might be a chance some of them could be found on Aliexpress or the like.
    C-Union also does an RF-only version which has 3 control channels + all channels + a bank switch to expand to 6 channels, and I'm not sure how that works, but I have a sneaking suspicion those might also be quite similar (although I'm not willing to bet on it) based on the fact it has 6 channels and based on identical model codes. It does, however, claim to have greater than 1-million codes ... I wonder if that's truly rolling-code or whether that's just an outright lie. Maybe it's a tall tale based on a 25 bit message = 2^25 possibilities = 33 million.
    Disclosure: I have no links with the companies, and I have no interests in promoting their products. In fact, I do not endorse their products for obvious reasons.
    - Gough
    mcb1 over 10 years ago in reply to Gough Lui
    The 433 Mhz are available in US plug.
    I did a bit about it in my "Forget-me-not" design challenge.
    Forget Me Not :  eLDERmon  Hardware Hacking #3
    The link I provided seems to detectign the source IP and pushing me to the Aus site.
