John Alexander's Blog Macro - The art of seeing clearly!
  • Author Author: Problemchild
  • Date Created: 3 Aug 2013 3:59 PM Date Created
  • Views 608 views
  • photography
  • pcb
  • projects
  • macro
Problemchild
Problemchild
3 Aug 2013
I'm sure many of us here are getting long enough in the tooth that we need to move PCBs and other parts away from you in order to focus on them.
Conversely or should I say perversely the world is intent in puting millions of components on boards that look like dust and writing that is in some
sub nano metre font. Connectors are little better at least when they are designed for humans, get the "robot only" ones then you are once again in the same senario.
My solution for this is simple, take photos, yes it is that simple image a good macro function on your compact or better still a macro lens on your DSLR and you can once
again see clearly.
Don't be a hero strugling with a crappy magnifier take a photo zoom it up as much as you need, it's also good as a memory aid or to add pizaz to your reviews or at least fill some space up when you are
finding it tough to fill the page ... Good luck.
    mcb1 over 13 years ago
    John is quite right.
    This picture was taken to show the need to bend the header pins prior to insertion, as they are too wide for the header socket.
    This was taken to show where to cut the trace to the smd LED since the silkscreening was slightly out.
    There were several attempts made before final success.
    I should have taken the photo before trying to cut it.!
  • Problemchild
    Problemchild over 13 years ago in reply to mcb1
    the photos are cool thanks for that personally I think they add a lot to the subject matter.
    when you are having difficulty describing something in words do it in the form of a picture or diagram.
    Also if you are complaining to some one say on Ebay  for some wrong or damaged part ..send a photo then there is no argument !
