John Alexander's Blog Macro - The art of seeing clearly!
  • Author Author: Problemchild
  • Date Created: 3 Aug 2013 3:59 PM Date Created
  • Views 611 views
  • photography
  • pcb
  • projects
  • macro
Problemchild
Problemchild
3 Aug 2013
I'm sure many of us here are getting long enough in the tooth that we need to move PCBs and other parts away from you in order to focus on them.
Conversely or should I say perversely the world is intent in puting millions of components on boards that look like dust and writing that is in some
sub nano metre font. Connectors are little better at least when they are designed for humans, get the "robot only" ones then you are once again in the same senario.
My solution for this is simple, take photos, yes it is that simple image a good macro function on your compact or better still a macro lens on your DSLR and you can once
again see clearly.
Don't be a hero strugling with a crappy magnifier take a photo zoom it up as much as you need, it's also good as a memory aid or to add pizaz to your reviews or at least fill some space up when you are
finding it tough to fill the page ... Good luck.
    DAB over 13 years ago
    Hi John,
    I have good luck using one of the cheap neck scope cameras.  I got mine for about $99 USD and they come with a number of different heads so that you can push them into tight places.
    I experimented with it over a PCB and found them very useful for reading IC codes.
  • Problemchild
    Problemchild over 13 years ago in reply to DAB
    I havent really had much luck with those "snake" cams but I've had plenty with my Lumix TZ20 which I use loads for this job.
    I have it on a koenig KN17 tripod which is like £7 delivered from EBAY it's a bit crappy but at least it holds it vaguely in the right direction image
  • Problemchild
