John Alexander's Blog Raspberry Pi Thermal Video
  • Author Author: Problemchild
  • Date Created: 25 Aug 2013 11:28 PM Date Created
  • Views 1465 views
  • Comments 5 comments
  • xbmc;raspbmc
  • raspeberrypi
  • raspberryp-pi
  • raspberry_pi_xbmc
  • thermal_imaging
  • flir
  • xbmc
Problemchild
Problemchild
25 Aug 2013
My mate's Raspberry PI is somewhat faulty and crashes once it gets warm or the likes
so I decided to use my FLIR i7(new toy spoiler image)  to video it during booting XBMC,
then again playing some videos off the USB stick. note that during all of this the USB/NIC
chip actually is hotter than the CPU/GPU doing all the heavy lifting ...very odd!
    They just announced a new heat sink:
    http://www.element14.com/community//docs/DOC-55389/l/stop-your-raspberry-pi-from-overheating-with-the-new-heatsink-from-element14
    but apparently it's only for the cpu, not the USB/NIC.
  • Problemchild
    Problemchild over 13 years ago in reply to e14 Contributor
    Thanks for the information.I sell heatsinks and the linke on my Ebay site ...They do work quite well and even keep this unit more reliable but in fact this RPI dies regardless when the NIC just fails image
  • Problemchild
    mcb1 over 13 years ago in reply to Problemchild
    Thats a great video.
    It has helped to reassure me that there should be enough heat to help de-freeze my camera, and that I should keep the camera close to the USB/NIC chip area.
    I seem to recall a batch had issue with this chip overheating ... it may be one of them.
    e14 Contributor over 13 years ago in reply to mcb1
    It was the rev 1 boards that mainly had the overheating problem.
    This looks like a rev 2 board, with the mounting/alignment hole visible.
    Rev 2 fixed the 1V8 power problem that jamodio found, and I think it also
    uses more solder under the LAN chip for a better thermal connection.
  • Problemchild
    Problemchild over 13 years ago in reply to mcb1
    Yes they produce quite a bit of heat considering. However i'm not sure that even that is enough for up a mountain.
    Depending on the enclosure consider a few power resistors for heating and maybe some insulation and a fan for the summer.
    This is what the proper  security enclosures use.
