John Wiltrout's Blog Attempt to capture sprectrums of LEDs
  • Author Author: jw0752
  • Date Created: 22 Aug 2015 6:27 AM Date Created
  • Views 923 views
  • Comments 12 comments
  • led_spectrum
jw0752
jw0752
22 Aug 2015
Earlier today in a blog post  http://www.element14.com/community/community/design-challenges/vertical-farming/blog/2015/08/16/use-of-leds-in-vertical-farming
I volunteered to try to capture the spectrums of some of the common LEDs. The discussion in that thread had been about the effectiveness of LEDs as grow lights for the Vertical Farming Challenge. I have a cheap spectroscope that I got to show the grandkids about how we can know the elemental composition of things by looking at their spectra. The poor quality of my results made me decide to present the pictures as a separate Blog so that I wouldn't mess up the other discussion . I have reference the other discussion above and I will cross reference this one in that thread.
There were a couple strikes against me from the start as the spectroscope was cheap and my camera was never designed to take pictures in a spectroscope.
Here is a picture of the bright line spectrum of a fluorescent light taking after 20 picture and 2 hours of experiments.
Notice the bright green line at 546 nm. This line is from the Mercury in the fluorescent tube. My hope was to get images like this of the light from different color LEDs but that wasn't to be.
I fell back on plan "B" and used a diffraction grating in front of the different color LEDS and photographed the spectrums created on the grating.
Here is a picture of the spectrum  of a RED LED. In this case I could see no spread outside the Red in the spectrum.
I next chose an Amber colored LED and this time we get a few colors in our spectrum.
Moving on to the Green LED we also see a fairly good spread of color in the spectrum.
The Blue LED had some spread to the longer wave lengths that I could see with my eye but the camera had difficulty capturing them.
Finally I took a picture of a white light LED and got the best spectrum, as we might have expected.
Other than a curiosity this information will be of little help in the Vertical Farm Project. I was surprised that the LEDs that I tried had as much spectral spread as they did. I really expected a much narrower band of light.
    shabaz over 11 years ago +3
    I'm impressed it was able to resolve the amber and green LEDs to quite some detail - more than the datasheet reveals I bet. And examination of your camera image would probably help with intensity measurements…
    shabaz over 11 years ago +2
    Hi John, Wow - this is a really great experiment, and still provides valuable information. Also it shows that sometimes we should try to explore to this level, so that we understand components better.…
    jw0752 over 11 years ago in reply to shabaz +2
    Perhaps I should post it on the UFO Enthusiast website and get everyone excited. The full diffraction grating image of the white light did remind me of some of the HUBBLE images of galaxies.
    DAB over 11 years ago
    Great post John.
    The color LED's are usually created with one specific output band with a little output in other areas.
    When you combine LEDs you get mixing as the wavelengths interact with each other in front of your sensor to give you the appearance of more spectral spread.
    For growing plants, the mixing is usually enough to permit the plants from pulling in the light they prefer for photosynthesis.
    As others have stated, each plant likes specific wavelengths and just about all of them reflect green.
    Most absorb deep red and infrared to fuel their growth.
  • shanesissons
    shanesissons over 11 years ago in reply to DAB
    Keep hearing alot about not needing green but I think I'm still going to include it so that it can be used for plants that do need more of that side of the spectrum would rather spend 10 minutes soldering now than have to disassemble and Re solder at a later date
    DAB over 11 years ago in reply to shanesissons
    You cannot go wrong using a broad spectrum of "white" light.
    That way the plant takes what it wants.
    jw0752 over 11 years ago in reply to DAB
    Reminds me of why I like to go to Buffets.
