John Wiltrout's Blog Hacking a Toroidal Transformer
  • Author Author: jw0752
  • Date Created: 15 Mar 2017 5:45 AM Date Created
  • Views 2795 views
  • Comments 13 comments
  • toroidal_transformers
jw0752
jw0752
15 Mar 2017
I have this beautiful Toroidal Transformer but it is 19 Volts and I need 24 Volts for my application.
It has a nice big donut hole and I have plenty of 16 GA solid enameled wire so I decided to add a few more windings. The first step was to figure how many windings I would need. I used some lighter gauge wire and wound 10 windings, hooked up the transformer and measured the voltage. I had 1.7 volts for the ten windings so 29 windings should give me the boost I need. This can't be too hard, I thought. I made a loose coil of wire and kept winding it around and around until I had the thirty that I needed. Next I secured one end of the wire to one of the existing wires and started to work backwards. I pulled the wire as tight as I could and went around and around until I had worked my way back to the last wind. Here is what it looked like.
Now that looks simple enough but I am writing this blog to let my hands stop aching. That was really hard work. I had to wonder how they wind these transformers when they have to put hundreds of winds on them. I can't imagine what kind of machine would be able to perform what I just did with my hands. If anyone knows how they do it I would really like to know.
I next used some cloth tape that I had and began to wrap strips around the transformer to hold the windings in place and to protect the wire. Here is the transformer after this procedure.
Finally I figured out the correct phase so that the voltage in my windings would add to the existing secondary and made a good solder connection. A few more winds of cloth tape to polish things up and I was done. A test of the transformer revealed 25 volts output with 118 Volts input.
Now that my hands are rested I am going to go back and make another one.
  • rachaelp
    rachaelp over 9 years ago in reply to mcb1 +4
    mcb1 wrote: while I was writing my reply you need a faster keyboard ... 3 mins! I don't think the keyboard speed was the issue. It's early here in the UK and I haven't had anywhere near enough caffeine…
  • kas.lewis
    kas.lewis over 9 years ago +3
    Hey jw0752 , Its fun looking at everyday objects that we take for granted and wonder how they automated a system to produce whatever the item may be. It definitely does get interesting I'm sure. Kas
  • rachaelp
    rachaelp over 9 years ago +3
    Hi jw0752 , I thought it was a very good question when you wondered how commercial toroid winding machines work. Fortunately YouTube has the answer! https://www.youtube.com/watch?v=82PpCzM2CUg Nice work…
    mcb1 over 9 years ago
    That's great work and useful tip about how to work out the number of turns required.
    Many years ago I saw a machine for winding toroids (well I think it was).
    It was a circle through the core, and I'm trying to picture how the wire was fed ...
    but I do recall that it had a centre piece that came off/lifted ...it did something.
    This one was large, so whether it's the same technology ??
    mcb1 over 9 years ago in reply to mcb1
    Actually it's all shown here.
  • rachaelp
    You beat me to it, you snuck in there quick while I was writing my reply!
    mcb1 over 9 years ago in reply to rachaelp
    We used to have a business here in Chch that wound coils.
    This was in the days before internet and mass buying from China involved looking into a dead tree.
    Not sure if it's still going as there are armature rewinding happening, so it's likely.
    I have the bits for a power supply like jw0752 (thanks John) and I'm busy thinking about where I can raid some transformers, along with what voltage I want.
  • rachaelp
    I don't think the keyboard speed was the issue. It's early here in the UK and I haven't had anywhere near enough caffeine yet! image
    I keep looking at all the projects John does and his power supplies look really excellent, I wish I had the time to replicate some of these myself, but with work at the moment I don't have enough time to make much progress on the projects I have already started image I'll hopefully have some more free time soon!
    Best Regards,
    Rachael
    jw0752 over 9 years ago in reply to mcb1
    Thanks Mark and Rachael for digging up that interesting video. They apparently measure off the length of wire needed onto the hoop and then reverse the direction and wrap it onto the core. Very ingenious and a lot easier than the way I did it. My hands and arthritis are still killing me.
  • rachaelp
    rachaelp over 9 years ago in reply to jw0752
    Yes I thought it was ingenious too. I'd not really considered how this worked for volume production of transformers before until you raised the question, definitely interesting to see how it's done.
    I'm very much looking forward to somebody (i.e. you image ) trying to construct some DIY version of this for a home lab image.
    On a more serious note, I hope your arthritis isn't playing up too much as a result and your hands recover soon so you can get back to building cool things in your lab! image
  • rachaelp
