John Wiltrout's Blog Mystery Part from the 1970s
  • Author Author: jw0752
  • Date Created: 7 Oct 2016 5:17 AM Date Created
  • Views 708 views
  • Comments 5 comments
  • old_tech
jw0752
jw0752
7 Oct 2016
While digging through my stores of old and obsolete parts I came across this 3.5 X 2.5 X 1.25 cm black box with 4 leads and no markings.
I can remember it being in my stock of parts back in the late 1960s and early 1970s when I was repairing equipment for the Radio Shack but I can not place the piece of equipment that it was used in. I also was not sure exactly what it was. With only 4 leads the puzzle seemed solvable.
An Ohmmeter check of the leads showed that there is a diode effect between the two leads on the left and no connection to the two leads on the right. The two leads on the right had a non-polarized resistance of 300K. This looked suspiciously like the readsing one might expect from some sort of giant optocoupler. I had to check the Wikipedia listing on LEDs to see if they had been invented by the late 1960 era and was pleased to see that practical devices existed as early as 1962. To test my theory I connected a 20 mA forward biased current to the left leads and once again checked the resistance of the right two leads. The resistance had dropped from the previous 300K down to about 50K. The non polarized nature and relatively high resistance of the right two leads seems to indicate a photo resistor output. The size of this device compared to optocouplers currently in use is a good testament to how far and fast the technology has evolved.
I am not sure if I will ever find a use for it but this is true of perhaps 95 percent of the components stocked on the shelves and in the nooks and crannies of my lab.
  • D_Hersey
    D_Hersey over 9 years ago +1
    Looks awful big. Could it be a SSR?
    Jan Cumps over 9 years ago +1
    If you don't have plans for the component, you could maybe try to open the enclosure?
    DAB over 9 years ago +1
    I remember seeing those things in circuits, but my memory is no longer able to put a name on it. From the size, I would think that it was built as some type of power switch or controller. Definitely an…
  • D_Hersey
    jw0752 over 9 years ago in reply to D_Hersey
    The lack of any heat sink and the relatively high output resistance makes me suspect it is not an SSR.
