John Wiltrout's Blog Reverse Engineering an Alarm Siren Module
  • Author Author: jw0752
  • Date Created: 17 Jan 2015 7:42 AM Date Created
  • Views 2861 views
  • Comments 23 comments
  • circuit_board_to_schematic
  • reverse_engineering
jw0752
jw0752
17 Jan 2015
One of the things that I enjoy doing is taking a small one or two sided circuit board and creating a schematic of it. Today I have a circuit board from a 105 db piezo siren for which I am going to create a schematic.  Here is the Module.
The first step is to get some paper and choose a starting point. In this case I picked the output transformer and then worked my way back. As you can imagine the board must be flipped back and forth and ones perspective must constantly shift from topside to mirror image and back. The resistors must be read and measured if they can not be seen. This is also done with the capacitors. On this board the identification of the small green mylars were face to face and so one had to be removed to determine the value. When the rough draft of the schematic is finished it is never very pretty. Here is my rough draft.
This is obviously not very good or very clear. In order to not put too many line on this draft the ground line was replaced with ground symbols and one junction point was labeled #3 and a second junction point was labeled *. What happened to #1 and #2? I am not sure it just seemed ok at the time to call them * and #3. After the rough draft is finished I use it to produce a more conventional looking hand done draft. Here is what it looks like after it has been cleaned up.
This one while still not very neat at least looks more conventional and at this point I also add component numbering. I also take close up photos of the board and label the components to match the schematic. This serves to tie things together and to make certain that I have not left anything out of my schematic. Here are the pictures and labels that correspond to the schematic.
Now I take all the drafts and produce a CAD drawing of the schematic to complete my file on this particular circuit.
This process is good exercise for the brain and gives me a very good understanding of the circuit by the time I have finished.
    jw0752 over 11 years ago in reply to mcb1 +2
    Yes Mark you are correct on a number of counts. With the advent of multi-layer boards and SMD parts I can see the end of the trail for people like myself who like to repair circuit boards. Through the…
    jw0752 over 11 years ago in reply to clem57 +1
    Hi Clem, The circuit came from a Radio Shack Alarm Siren that I was using in one of my inventions. Something went wrong and it fried. I fixed it with a new filter cap and new output transistor before I…
    shabaz over 11 years ago +1
    Hi John, Thanks for the great blog post : ) This is nice, and also probably goes to show that when cost-saving, transistors may end up cheaper than a 555 circuit by a few pence/cents, and hence make more…
    DAB over 11 years ago
    Hi John,
    Nice post.
    I have done more of these reverse engineering tasks than I care to remember.
    I agree that it is an excellent practice to learn.  There are a lot of secrets hidden in some circuits and you are always rewarded by figuring them out.
    One of my dream projects is to have and system that you can just take front and back pictures of the board in question and have a circuit diagram drawn automatically.
    It would be a great task for a collaborative project.
    jw0752 over 11 years ago in reply to DAB
    Hi Donald,  Actually I am surprised that the program you mention doesn't come as an App for one of the smart phones all my grandkids have. They showed me the other day that there is a app where they let the phone listen to a couple bars of music and the phone promptly Id's the song. Wish I had that when I get a song bouncing around in my head that I can't quite put a name to. Thanks for your reply to my blog.
    mcb1 over 11 years ago in reply to jw0752
    There is even one that you take a pic of the product label and it goes away and finds the info and where to buy.image
    In theory you would need a reference mark (could be manually done), and the size needs to be the same.
    But scaling images isn't that hard.
    Maybe there is little market for it.
    Many manufacturers provide schematic information to authorised repairers, so you're catering to a old equipment or non authorised type repairers.
    Thankfully the digital revolution has made it easy to archive older manuals, but may ended up as landfill.
    There is a great program here to keep old car manuals.
