John Wiltrout's Blog Sticky Analog Voltmeter
  • Author Author: jw0752
  • Date Created: 18 Dec 2016 7:07 AM Date Created
  • Views 1679 views
  • Likes 10 likes
  • Comments 9 comments
  • analog_meters
jw0752
jw0752
18 Dec 2016
I happened to notice the other day that an analog voltmeter that I built a couple years ago was reading 10 volts. Now this alone would not have been of any concern except for the fact that the power supply was not turned on nor had it been turned on for several days. I went over and tapped the meter and it dutifully dropped back to zero. Years ago when I did service work for Radio Shack it was common to have the little analog multimeters come in for repair with stuck meter movements. I would take them apart and the usual cause would be a metal filing suspended in the magnetic field where the movement coil would normally swing. Once the filing was spotted any sharply pointed ferromagnetic tool could extract the filing by touching it with the point of the tool and pulling it out using the magnetic field. Since the meter movement of this power supply was not very expensive I expected to find a similar problem. I really like this power supply and I really didn't want to have to replace the meter so I popped the front cover off. To my delight this is what I found:
There just south east of the DH-670 was a hair like finger of white paint acting like a tiny ratchet. The needle could pass by it on the way up but on the way down it would get hung up. The picture also revealed a couple other signs of the quality of this meter. Note the rust on the screws holding the front plate and even a dust bunny clinging to the left mounting screw pulled perhaps from the sleeve of the factory assembler. Fortunately when I removed the finger of paint and the dust bunny the meter started working as good a new and since I have tolerant standards in my test equipment more than adequate for me.
    mcb1 over 9 years ago +4
    Well done capturing the culprit and such a detailed photo. I've always maintained that having a good look at the item you're trying to repair will often spot the issue. I've seen others plunge in with…
    jw0752 over 9 years ago +4
    Thanks Guys, I have to thank Millie for the improved pictures as she got me a slightly upscale camera for my last B day and it allows me to focus to the front of the lens. My biggest problem is usually…
    Jan Cumps over 9 years ago in reply to mcb1 +3
    mcb1 wrote: ... and such a detailed photo. It is, isn't it? It's so nice to see blogs where the images have been composed as carefully as the text.
    DAB over 9 years ago
    Excellent job of searching for the problem cause and not just following the symptoms.
    Your getting good at this John.
