John Wiltrout's Blog Unusual Circuit board configuation
  • Author Author: jw0752
  • Date Created: 27 Mar 2017 5:20 AM Date Created
  • Views 1116 views
  • Likes 9 likes
  • Comments 12 comments
jw0752
jw0752
27 Mar 2017
I was busy salvaging a bunch of Dental electronic equipment for interesting parts when I came across this interesting circuit board construction and I thought you might get a kick out of it.
This is a driver circuit from a handheld LED composite cure light. It allows the operator to select a timer setting and drives a high power LED that has it's light output towards the blue end of the spectrum. The unit also controls a cooling fan the size of a dime to help cool the LED. In order to fit the needed components into a body witha diameter on the order of a broom handle they had to stack a set of circuit board disks 2.2 cm in diameter.  Pretty cool!
    DAB over 9 years ago +2
    Interesting stack. We used to use this technique in the old days where we needed to keep circuits in cylindrical devices like missiles and rockets. I would say they expected quite a bit of vibration given…
  • COMPACT
    COMPACT over 9 years ago +1
    Some of those PCBs are rather thick!
    mcb1 over 9 years ago +1
    I had a feeling it was inside a housing, that had limited size.
