John Wiltrout's Blog Unusual Way to Wire a small DC Motor
  • Author Author: jw0752
  • Date Created: 4 May 2017 11:12 PM Date Created
  • Views 1577 views
  • Likes 8 likes
  • Comments 14 comments
  • motor_circuits
jw0752
jw0752
4 May 2017
Despite 60 years of playing with electronics this is the first time I have seen a DC motor wired in this fashion.  At first I did not expect it to work on DC current but to my surprise it took off and ran perfectly. Furthermore it did not matter if the polarity was forward or reversed. The motor continued to spin happily along. Just for the fun I also applied an AC current and once again the motor continued to whirl away. Here are some pictures of the motor wiring:
Just to clarify how the motor is wired I also produced this small schematic:
On first appearances I assumed the motor would start to turn and then stop when the small tantalum capacitor became charged. I did not initially understand why this did not happen. I am hoping some of my friends on the Forum with more experience and knowledge will confirm my speculation that the counter EMF in the motor actually discharges the capacitor allowing it to accept a second charge and continue to maintain the magnetic fields that spin the motor. I suspect that the low ESR of the Tantalum caps makes their charge and discharge rapid enough to facilitate this process. I do not know why the designer of the piece of equipment where this small cooling fan was used chose to use this particular circuit. It was something new to me and it caught my attention. Now I just want to understand it.
    jw0752 over 9 years ago +5
    One final observation. Using a Tantalum capacitor as I have done in these experiments does damage it and makes it unusable in a normal power application. To verify this I tested one of the 33 uF caps that…
    jw0752 over 9 years ago +4
    SOLUTION FOUND! I took shabaz suggestion to try to set up the circuit using a different motor and other components. I was not able to get the motor to turn. I ran some tests on the original motor and found…
    Tonight I will investigate whether the Tantalum capacitor has any characteristics related to temperature when it is hooked up in a circuit backward to normal polarity. I my previous post I was using the…
  • kas.lewis
    kas.lewis over 9 years ago
    Hello John,
    I've seen this arrangement (without the diode) on hobby motors. More specifically I used to see it on RC car motors. I never fully understood why but just assumed the cap help[ed to remove noise or power ripples from the power lines.
    If someone else could explain this better I would love to have that understanding as well.
    Kas
  • michaelwylie
    michaelwylie over 9 years ago in reply to kas.lewis
    DC motors can produce lots of noise themselves. I suspect the caps in the hobby RC application stop the wire motors from radiating interference, increasing the link range of the car.
  • michaelwylie
