Michael Wylie's Blog An Interesting Find
  • Author Author: michaelwylie
  • Date Created: 24 Mar 2016 6:15 AM Date Created
  • Views 971 views
  • fiber_optics
An Interesting Find
michaelwylie
michaelwylie
24 Mar 2016
I work with Fiber Optics these days (fiber sensing to be precise). I'd just come back from a survey and I was hooking up the field systems for testing back at the office when I found this bulkhead adapter on the front of a circulator box. Look closely and you'll see a piece of the Zirconia sleeve has broken off and is blocking the insertion path for the fiber cable. If I hadn't noticed this, I probably would have ruined whatever cable I would have tried to insert. Sometimes you just get lucky ...
{gallery} Broken Mating Adapter
Photo 1: Broken Zirconia Sleeve Material 1
Photo 2: Broken Zirconia Sleeve Material 2
Photo 3: Broken Zirconia Sleeve Material 3
    jw0752 over 10 years ago +1
    Good catch, Always good to keep ones eyes open and don't assume things are as they should be. John
  • michaelwylie
    michaelwylie over 10 years ago in reply to jw0752
    It was really interesting, because I had never seen one fail like this before. I found out later, they were cheaply made adapters (I'll give you one guess where it was made). Apparently the good ones have metallic sleeves.
  • michaelwylie
