Michael Wylie's Blog An Interesting Find
  • Author Author: michaelwylie
  • Date Created: 24 Mar 2016 6:15 AM Date Created
  • Views 971 views
  • fiber_optics
An Interesting Find
michaelwylie
michaelwylie
24 Mar 2016
I work with Fiber Optics these days (fiber sensing to be precise). I'd just come back from a survey and I was hooking up the field systems for testing back at the office when I found this bulkhead adapter on the front of a circulator box. Look closely and you'll see a piece of the Zirconia sleeve has broken off and is blocking the insertion path for the fiber cable. If I hadn't noticed this, I probably would have ruined whatever cable I would have tried to insert. Sometimes you just get lucky ...
{gallery} Broken Mating Adapter
Photo 1: Broken Zirconia Sleeve Material 1
Photo 2: Broken Zirconia Sleeve Material 2
Photo 3: Broken Zirconia Sleeve Material 3
    jw0752 over 10 years ago +1
    Good catch, Always good to keep ones eyes open and don't assume things are as they should be. John
    DAB over 10 years ago
    Yes, with optics you must always verify that your path is free of obstructions and that your surfaces are clean.
    Though if you are using some high powered lasers, you can get some very cool explosions.  Unfortunately these are quite expensive.
