NexGen Flight Simuator Documents: Synchro and Resolver Handbook and Guide
  • Author Author: phoenixcomm
  • Date Created: 17 Feb 2025 12:07 AM Date Created
  • Views 2800 views
  • Comments 11 comments
  • flight simulator
  • nexgen
  • synchro
  • hardware
  • Synchro Handbook
  • Synchro Application Guide
phoenixcomm
phoenixcomm
17 Feb 2025
imageIf you work with robotics, avionics, an other fields that use angles you might just run into one or more these things. They are motor like devices that can transmit, or receive angles called Synchros in older aircraft they are used in pairs, imagea transmitter (tx) and a receiver (rx) . As you can see in Figure 1 by moving CG the CR will move exactly in step with its counter part. This figure is from Synchro Application Guide. There is lots more information in the Synchro handbook.
    DAB over 1 year ago
    Whoa, this takes me back to the early 1980's when I was controlling Syncros for a FLIR using radar information.
    They were very responsive so I had to build software to slow them down so the user had time to assess what was going on.
    DAB over 1 year ago
  • phoenixcomm
    phoenixcomm over 1 year ago in reply to DAB
     DAB how does software slow down a pair of synchros?? maybe you mean hardware?? either way you have me intrigued.. Please tell me more!  ~~ Cris.
    DAB over 1 year ago in reply to phoenixcomm
    I set up a loop where I would only allow the servo to move about 5 degrees at a time, I forget how quick the loop ran, probably about ten times per second..
    That implementation stops the servo from trying to do instantaneous movement from one position to another.
    You can change how often you allow the servo to move and how much you allow it to move, you have to adjust these values based upon the load you have on the servo..
    The end result is that you can achieve a very controlled movement of your sensor.
