NexGen Flight Simuator How To Rebuild a Dell Precision 690 Server (From Scratch) 1.
  • Author Author: phoenixcomm
  • Date Created: 7 Feb 2024 5:30 PM Date Created
  • Views 1135 views
  • flight simulator
  • nexgen
  • dell
  • rebuild
  • Precision 690 Server
  • electronics taredown
phoenixcomm
phoenixcomm
7 Feb 2024
imageFirst, this server was donated by a friend of mine who smokes! The first thing I did was to take it completely apart, every bolt, every panel, and run them through the Dishwasher! The parts I removed were:
      • Right Side Door
      • Large Plastic Fan Shroud
      • Right Side Upper Drive Bays (2)
      • Power Supply
      • Mother Board with the two CPUs and Coolers
      • Front Metal Bezel along with the spacers.
      • Front Plastic Black Bezel
      • DVD R/W  x 2
      • Floppy Disk Drive
      • Carrier for the Floppy Drive
      • Dual Font Fan Assembly
      • Rear Cage Support
      • Rear Metal Vent
      • Front Jack Assembly
      • CN-0RH223  Power Supply P2 Extension Cable
      • CN-0TH82  Power Supply P2 Extension Cable
      • CN-0RH233  Power Supply Video Card Extension Cable
      • CN-0U9692  Power Supply
Now the fun begins I also wanted to remove Left Side Cover, This was a pain in the you know what to remove!! and was even worse to reinstall. Some cables are in the way of them so, remove them, they are:
      • CN-0J741     Flat ribbon Floppy Disk cable
      • CN-0JD739  Flat ribbon Front Panel USB Cable
      • CN-0JD841  Firewire Front Panel I/O Cable (RED)
      • CN-0TH82   Power Supply P2 Extention Cable
CN-0CD674UA
CN-0CH974
CN-0FM857
CN-0GF459
CN-0JD739
CN-0JD841
CN-0KH945
CN-0RH223image
CN-0RH233
CN-0TH082
CN-0U9692image CN-0YC653
FF219/P148J
FFD419
FH281
HC946
KX230
6T270-01
blank blank
Now, you found all of the blind screws, removed them, and have the panel off.
REASSEMBLY:  You will have to wait till part 2. ~~ Cris
FYI I will be updating the pictures below from time to time.
UPDATES:
2/7/2024 Add a few pictures ~~ Cris H.
  • javagoza
    javagoza over 2 years ago
    Can we place bets on how many screws will be left after reassembly?
  • phoenixcomm
    phoenixcomm over 2 years ago in reply to javagoza
     javagoza image I don't know some I will not put back as they are BLIND, and I can live without them!!! For Shits and Giggles I might post a picture of the Rear panel by itself, with all screw holes highlighted!!! ~~ Cris H.
    BTW why does everybody ask that question?
  • phoenixcomm
