NexGen Flight Simuator How To Rebuild a Dell Precision 690 Server (From Scratch) 1.
  • Author Author: phoenixcomm
  • Date Created: 7 Feb 2024 5:30 PM Date Created
  • Views 1135 views
  • flight simulator
  • nexgen
  • dell
  • rebuild
  • Precision 690 Server
  • electronics taredown
phoenixcomm
phoenixcomm
7 Feb 2024
imageFirst, this server was donated by a friend of mine who smokes! The first thing I did was to take it completely apart, every bolt, every panel, and run them through the Dishwasher! The parts I removed were:
      • Right Side Door
      • Large Plastic Fan Shroud
      • Right Side Upper Drive Bays (2)
      • Power Supply
      • Mother Board with the two CPUs and Coolers
      • Front Metal Bezel along with the spacers.
      • Front Plastic Black Bezel
      • DVD R/W  x 2
      • Floppy Disk Drive
      • Carrier for the Floppy Drive
      • Dual Font Fan Assembly
      • Rear Cage Support
      • Rear Metal Vent
      • Front Jack Assembly
      • CN-0RH223  Power Supply P2 Extension Cable
      • CN-0TH82  Power Supply P2 Extension Cable
      • CN-0RH233  Power Supply Video Card Extension Cable
      • CN-0U9692  Power Supply
Now the fun begins I also wanted to remove Left Side Cover, This was a pain in the you know what to remove!! and was even worse to reinstall. Some cables are in the way of them so, remove them, they are:
      • CN-0J741     Flat ribbon Floppy Disk cable
      • CN-0JD739  Flat ribbon Front Panel USB Cable
      • CN-0JD841  Firewire Front Panel I/O Cable (RED)
      • CN-0TH82   Power Supply P2 Extention Cable
CN-0CD674UA
CN-0CH974
CN-0FM857
CN-0GF459
CN-0JD739
CN-0JD841
CN-0KH945
CN-0RH223image
CN-0RH233
CN-0TH082
CN-0U9692image CN-0YC653
FF219/P148J
FFD419
FH281
HC946
KX230
6T270-01
blank blank
Now, you found all of the blind screws, removed them, and have the panel off.
REASSEMBLY:  You will have to wait till part 2. ~~ Cris
FYI I will be updating the pictures below from time to time.
UPDATES:
2/7/2024 Add a few pictures ~~ Cris H.
    DAB over 2 years ago
    It will be interesting to see if you can get it up and running.
    FYI, arn't there always left over screws after you take something apart and put it back together?
  • phoenixcomm
    phoenixcomm over 2 years ago in reply to DAB
     DAB This question is so old it has hair on it! image
  • phoenixcomm
