NexGen Flight Simuator New Tool Day: Kett Power Shear
  • Author Author: phoenixcomm
  • Date Created: 27 Jul 2024 11:29 PM Date Created
  • Views 1082 views
  • Likes 10 likes
  • Comments 9 comments
  • flight simulator
  • nexgen
  • diy hardware
  • Kett KD-400
phoenixcomm
phoenixcomm
27 Jul 2024
imageOh well, this orb keeps spinning and throws stuff at you some good, some well maybe not so good. I made a detour to the 25 cents shop to see if they had gotten in some more image  sockets. BTW they are only $5.00 each. that's about 75% off the truck, so what they are a little used.  As I turned to go and pay up I think there were 3 of them, I saw what looked like an electric drill, but there was something familiar with the nose and no chuck. I was a power nibbler, a Kett KD-400 Power Shear, which will cut 18ga steel and 20 ga stainless. When I looked down at the price I was shocked, it was 33 bucks. I did not even check eBay! (later their cheap one was over 50 bucks and it looked roched!
Needless to say, it followed me home! I can put to good work on the sim. I am tired of cutting holes badly with the zip saw! I will put a pic up soon as well as the price tag!!
So here is a nice vid showing the tool off.
    shabaz over 2 years ago
    Impressive, looks like a very clean cut from the video. I wouldn't have expected that if someone had described the tool to me.
    I was looking for gardening snips for my mum, and noticed that there are motorized versions of those too. But, I couldn't see many (any) safety features, so I passed on that since elderly hands shake a bit. I think the manufacturers need to do a much better job with say sensors that detect where both hands are before actuating garden shears.
    beacon_dave over 2 years ago in reply to shabaz
    "...But, I couldn't see many (any) safety features..."
    Some do have safety features
       https://www.youtube.com/watch?v=b5gHz0pR3JY
    but in some cases you have to remember to turn them on and then probably remove your PPE (gloves) to get them to work.
    You could perhaps look at placing a momentary switch on the battery pack which means the second hand has to be away from the blade when pulling the trigger but then the trimmed piece can't be held and will drop to the ground. Also if you are on steps, then you can't hold onto the steps with your free hand.
  • phoenixcomm
    phoenixcomm over 2 years ago in reply to beacon_dave
     beacon_dave what battery pack???  neat safe future.
    shabaz over 2 years ago in reply to beacon_dave
    Not bad! Better than the few I saw on Amazon.
    Maybe they thought, even if the glove is cut, eventually it will detect flesh : ) I went with mechanical scissor-shaped handle ones in the end, since there was just not enough information on the motorized ones that I saw.
    beacon_dave over 2 years ago in reply to phoenixcomm
    A number of the pruning secateurs that Shabaz is referring to are powered off a cordless power tool battery pack.
    Usually there is an on/off switch close to the battery pack that arms the tool and then you have to activate the trigger a couple of times to place it in operate mode.
    You probably wouldn't be cutting through glove on the other hand at the same time though.
    Manually powered ones are probably a safer option. If you need any more cutting power than that, then garden loppers are probably a better option.
