NexGen Flight Simuator NexGen: Getting the lab working
  • Author Author: phoenixcomm
  • Date Created: 21 Dec 2014 9:38 PM Date Created
  • Views 1520 views
  • Comments 19 comments
  • Eatontown NJ
  • regatran
  • tr035-0.5
  • old_gear
  • nexgen_flight_simulator
  • electronic Mesurements Co of Red Bank NJ
  • diy_cockpit
phoenixcomm
phoenixcomm
21 Dec 2014
Well here we are now trying to get some power supply working for NexGen. Well I have luging this beast around for more than a few years, and I need some juice for my projects. It seems that my Kepco JQE-6-10 output stage took a dump. image BTW if you have a service manual for this unit please let me know..  I would love to make a copy.image
So... This one was on top of the pile... ok I plugged it in and nothing.. So I checked the fuses and they were both missing so I tossed in the two fuses and bang its... alive. image
Here are the specs:
Manufacture: Electronic Measurements Co of Red Bank  Eatontown, NJ
Model:
Programmable Regatran
TR035-0.5
Serial Number: 3G 4456
Output Voltage: 0 - 36vdc
Output Current: ?
Just a note: If you look at the controls (TL, BR) and the binding posts you will notice that they are bakelite.
This unit BTW if you look at the serial number you will notice the date code: 44 week of 1956 so this unit was built in the last week of October or the first week of November, which makes this power supply is 58 years old! and still works!!
Keep tuned in more to come; image
~~ Cris H.
BTW: at UTA (University at Arlington) we have a maker lab in the Library.. So I can replace the knobs. The only thing that I have to pay for is the nylon.
As Requested:
image image image
Figure 2
Top View
Figure 3
Bottom View
Figure 4
Close Up of the large capacitor.
PS 30Jan2015
I have just inserted picture #4. The Capacitor has a 6-63 date stamp! 2015 -1963 = 52 so about 52 years old...
    e14 Contributor over 11 years ago in reply to phoenixcomm +1
    Hi Cris, Small world... Middletown is my old stomping ground too. MTHS north... a LONG time ago! Yes, Lab-Volt as you've found was a product of Buck Engineering. I'm not sure if Buck is still in business…
    Hi Cris,
    That's not the way the serial numbers work. The 4456 is simply a numerical sequence number.
    The first two digits are a date code. The " 3 " is the year and the " G " is the month.
    In this case, there is some ambiguity, the year could be 1973, but I believe that the Regatran you have is from 19 sixty 3 and the month G is July.
  • phoenixcomm
    phoenixcomm over 11 years ago in reply to e14 Contributor
    Jeff you are right on the date as born out by photo #4 but that is still 52 year old supply that still works... LOL
    I know!  pretty amazing...  E/M made some good stuff back then.  The 'next generation' of these, called the "SCR", "TCR" were just as good.  More power too.  If you ever need lots of power, say 10kW to 15kW, be sure to try and find a used "ESS" series.  Good Luck with your project!
  • phoenixcomm
    Hey Jeff I lived over in freehold for high school but lived in middletown just north of red bank.. lol I believe E/M also had another product called Lab-Volt. they were GE meters and power supplies built into our work bench...image
    PS sorry that was Buck Engineering also a local..
    Hi Cris,
    Yes, Lab-Volt as you've found was a product of Buck Engineering.  I'm not sure if Buck is still in business, but Lab-Volt appears to have been bought by a company called Festo Didactics ...
    They were located over on Rte 34, a bit north of the airport.
  • phoenixcomm
    MGD... I went to Fairview then Thompson then Freshmen (64)  at MTHS near the police station mid way through we moved to Freehold and I went to FRHS!! Do you remember when the Nike Base blew up?? I lived across from the golf range on 35N.  I later went to work for Interdata (76).. down by the racetrack.. after the AF I used to hang out in the Red Bank hobby shop or in Eatontown at Atkinson and Smith. later down the road at the MG dealership. Do you remember the Studebaker showroom in Red Bank...
    I was at Thompson from 66 to 69, then MTHS from 69 to 71, so I gess I a couple years younger...
    Don't 'remember' when the base blew, but I've read about it a bit.  I think it was '58, wasn't it?  We had just moved back to NJ that year... I was 5.  I knew quite a few folks at Interdata, bet we're separated by one degree.  Who knows?  I might even know you, or at least have met... Hobby Headquarters, spent lotsa time there, Tom Cosgrove owns it now... Atkinson and Smith, practically lived there.  Was good friends with Paul Atkinsons son Doug... and the MG dealership?  You mean "World Wide Auto Imports" ?   Yeah, I pretty much lived there too... I was very into MG and Triumph back in the day.  Had a 58 MGA Coupe, a 60 TR3, and several other of those wretched machines.  If that Studebaker dealership was on the corner of Monmouth and Maple, it later was owned by a guy named Anderson and was a foreign car place.  He sold TVR for a while.  I worked for him for about a year or two back in the early 70s.
    Yeah, I bet we've crossed paths a time or two!
  • phoenixcomm
    This is so funny you can't make up this ***... I had several of the MGA I think the one I drove the most (not parts cars) was a bright red one... It was very distinctive as the nose had been cut off of it before I bought it.. I worked in the final test / integration.. did a lot with 7/32s and also the 8/32 #1 to Murray Hill...  I drove a blue B then 76 -78 ?? It had a black removable roof.. I used to hang out down at Ray's Garage on the shore and I cant remember the name of the guy that had a little garage and then opened the Porsche place. They fixed my shocks (had to cut them off) LOL .. Last deal I did was for a DB-3 basket case for 500 and my mom cussed me out and told me to take it back as I had too many carcases around at the time..
    *** we should meet up in facebook...LOL  https://www.facebook.com/cris.harrison.9
    I have no recollection of Ray's garage, where 'down the shore' was it?.. you talking about the Porsche guy on Shrewsbury Ave?  OMG, I know about carcasses... Mom's backyard was a regular junkyard.  If it was like that these days I'd probably be in jail... and the EPA would launch a full scale super-fund site!  No shyte?  A DB-3 ?  I guess you never got it on the road then?  I went to muscle cars after the sports cars... 500 HP monsters!  But there's still a place in my heart for SU carbs!
    Sorry, I don't do FB... too many scary ppl from my past I don't want to find me!  LOL!
  • phoenixcomm
    I'm on linked in as well more private Ok
  • phoenixcomm
    phoenixcomm over 11 years ago in reply to phoenixcomm
    Btw did you have a Mr Rapp (history8) or miss Cavalo (science 7)???
