NexGen Flight Simuator NexGen: Lab:B&K Precision 3010 Function Generator - Repair
  • Author Author: phoenixcomm
  • Date Created: 13 Apr 2020 6:14 PM Date Created
  • Views 1662 views
  • Comments 8 comments
  • test equipment
  • b&k precision 3010
  • restorerepairch
  • function generator
phoenixcomm
phoenixcomm
13 Apr 2020
THENimage
NOWimage
  • Black (Hot) and White (Neutral) ended up switched so 110 VAC ended up on my ground-plane! Push on connectors are a must! image
  • I replaced the bridge with 4 100vdc 5 amp monsters.  imageIt took quite a bit of heat to solder the big leads so I sub in an IR bridge  12DB6A
  • I have a lot of harmonics to fix.
  • The function generator parts still work. imagethat is to say triangle, sine and square wave are ok just with harmonics. Most likely killed some caps!
PROBLEMimage
DEAD DIODESimage
FIXEDimage
NEW BIG DIODESimage
  • cstanton
    cstanton over 6 years ago +3
    D: but what died!?
    DAB over 6 years ago +2
    Good job. DAB
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to cstanton +2
    cstanton not sure, but there is only AC on the 600-ohm outputs. So I had do get some stiffer diodes(4) for the bridge!
  • cstanton
    D: but what died!?
  • phoenixcomm
    cstanton when I put it back together by putting 115 on White and Neutral on black! ie I shot myself in the foot! image and the "harmonics" looks like an ungrounded scope probe!  image
  • phoenixcomm
