NexGen Flight Simuator NexGen: The Lab: Two is always better than one!
  • Author Author: phoenixcomm
  • Date Created: 5 Aug 2019 12:52 AM Date Created
  • Views 597 views
  • nexgen
  • the lab
  • realspace
  • work task lamp
  • rsvs103s
phoenixcomm
phoenixcomm
5 Aug 2019
Before I moved my very old task lamp with magnifier broke. image It broke at the base where everything swivels from, as this lamp is very old I could not find any parts online.  So I disassembled most of it and put it in my hope chest.
The other day while at Goodwill I found something that I was sure that it would do the job. Almost everything was there, from table clamp to shade, but it was missing springs, lens, and small parts. So I grabbed it.image
Building Frankenstein
  1. Remove the shade that holds the lamp, lens, etc.
  2. I was going to use the older upper bars as they were heavier. But I decided to keep the new ones.
  3. Remove the Black Zipcord and replace it with the wire from the old shade.
  4. As the old shade and pivot are heavier, I will use the old parts.
  5. Use wire splices to repair the power cable
  6. The new lamp uses a twist-in starter, the old lamp did not. So If I can I will use this.
  7. Reinstall the lens. and power it up. image
Please check back to see Frankenstein come to life.
    DAB over 7 years ago +1
    Nice fix Chris. DAB
    Nice fix Chris.
    Nice fix Chris.
  • phoenixcomm
    phoenixcomm over 7 years ago in reply to DAB
    Not quite done. but not a fix a SAVE!
    Cris
