NexGen Flight Simuator NexGen: The Lab: What to do with a Cuisinart 12 cup plus. use it to control a DIY Sand Blaster.
  • Author Author: phoenixcomm
  • Date Created: 31 Jan 2025 12:38 AM Date Created
  • Views 685 views
  • Likes 8 likes
  • sand blaster
  • Tools!
  • Cuisinart 12 Plus Coffee Maker
phoenixcomm
phoenixcomm
31 Jan 2025
imageimageI have a real problem with what to do with my Cuisinart 12 Plus that has no heat but the clock works. Rip the guts out and use it to control a DIY Sand Blaster, of course!
The cabinet will be made of 1/2" plywood painted gloss white inside. Lighting inside the box will be a strip of LEDs. I have this POS Sand Blast Kit (all in one), and I plan on using that for the guts. There is also an inlet for high-volume fresh air, most likely a fan of some sort.
The Box stands on 4 legs with a shelf under it, to hold two (2) buckets one for fresh sand and the second for recovered sand. To make it more fun I might add sensors in the buckets to measure if the used sand is full or if the fresh sand almost empty.  I found this DIYer on YouTube, looks like a good start for the box and legs.
Change of Plans. Pivot Time. I most likely will use an Arduino with an RTC module, and some multi-line display needs buttons to set the clock, I want to have a foot switch to control it
  • robogary
    robogary over 1 year ago in reply to phoenixcomm
    Thx. That's why my employer pays me the big bucks.  :-)
  • phoenixcomm
    phoenixcomm over 1 year ago in reply to robogary
     robogary You have just won the Stupidist but Funniest Comment of the Year!!
  • robogary
    Use the sand blaster part to clean to coffee cup  :-)
    DAB over 1 year ago
    Waste not want not.
