Hi all,
I just kind of randomly came across a thread discussing using nail polish to cover electrical connections to avoid shorts, especially for the backs of home made PCBs.
There are commercially available "conformal coatings" you can use, but they are somewhat more pricey, and I guess a fair bit more boring
So I went to the dollar store yesterday and picked me up some of this!
Only $1.50 (Canadian dollars even!)
I was thinking I might use it on a past or future PCB to coat the back.
This is the first time I've ever bought nail polish, which I think explains the conservative colours
It says "Kozmic Colours", so just imagine the variety available! I thought I'd avoid the sparkly ones though, as I wasn't sure if that might be conductive.
Then today I soldered a light resistor onto some wires, and then wished I had remembered to put on some heat shrink tubes. The shrink tubes were aaaalll the way in the workshop and I was being lazy
Then I realized I could probably use the nail polish for this!
It looks like it does the trick - as you can see in the pictures, it has fully coated the exposed wires. It's easier than dealing with heat shrink tubing, and can be added as an afterthought. It's not as rugged as heat shrink tubing, but for many of these smaller light-duty cases it's perfect.
Next time - red and black!
Cheers,
-Nico
edit: I just did a quick resistance test, and I can clip the test leads right beside each other on a (coated) pin of the sensor with full resistance.
Cancel
Vote Up
+2
Vote Down
Sign in to reply
More
Cancel
ntewinkel
in reply to DAB
Cancel
Vote Up
+3
Vote Down
Sign in to reply
More
Cancel
mcb1
in reply to ntewinkel
Cancel
Vote Up
+3
Vote Down
Sign in to reply
More
Cancel
Comment-
mcb1
Cancel
Vote Up
+3
Vote Down
Sign in to reply
More
Cancel
