Nico teWinkel's Blog Nail Polish Short-proofing?
  • Author Author: ntewinkel
  • Date Created: 26 May 2018 11:57 PM Date Created
  • Views 5266 views
  • Likes 10 likes
  • Comments 18 comments
  • nail polish
  • conformal
  • heat_shrink_tube
  • conformal coating
ntewinkel
ntewinkel
26 May 2018
Hi all,
I just kind of randomly came across a thread discussing using nail polish to cover electrical connections to avoid shorts, especially for the backs of home made PCBs.
There are commercially available "conformal coatings" you can use, but they are somewhat more pricey, and I guess a fair bit more boring image
So I went to the dollar store yesterday and picked me up some of this!
Only $1.50 (Canadian dollars even!)
I was thinking I might use it on a past or future PCB to coat the back.
This is the first time I've ever bought nail polish, which I think explains the conservative colours image
It says "Kozmic Colours", so just imagine the variety available! I thought I'd avoid the sparkly ones though, as I wasn't sure if that might be conductive.
Then today I soldered a light resistor onto some wires, and then wished I had remembered to put on some heat shrink tubes. The shrink tubes were aaaalll the way in the workshop and I was being lazy image
Then I realized I could probably use the nail polish for this!
It looks like it does the trick - as you can see in the pictures, it has fully coated the exposed wires. It's easier than dealing with heat shrink tubing, and can be added as an afterthought. It's not as rugged as heat shrink tubing, but for many of these smaller light-duty cases it's perfect.
Next time - red and black!
Cheers,
-Nico
edit: I just did a quick resistance test, and I can clip the test leads right beside each other on a (coated) pin of the sensor with full resistance.
    jw0752 over 8 years ago +5
    Hi Nico, I would be interested in learning more about its insulation value. I am sure you could increase the insulation value by putting multiple coats on it. If smell is any indication it should be pretty…
    mcb1 over 8 years ago +4
    This is the first time I've ever bought nail polish Are you sure .... For higher power/mains systems I can't see it meeting any sort of voltage rating, but for low voltage, if it gets you out of a problem…
    mcb1 over 8 years ago in reply to jw0752 +4
    I'm starting to get worried now that you boys are becoming proficient in buying and using nail polish. The proper coatings might be a worthwhile roadtest. What do you think rscasny ( about the road test…
  • ntewinkel
    ntewinkel over 8 years ago in reply to mcb1
    >Are you sure ....image
    Absolutely sure... I usually just borrow my wife's nail polish image
    Which reminds me, the reason I bought the cheap stuff is because my dearest uses the healthier and much more expensive stuff.
    >I can't see it meeting any sort of voltage rating, but for low voltage, if it gets you out of a problem, and it's handy .....
    Oh yes definitely don't be using that on anything serious. I'm thinking only on the low voltage projects. I'm not even sure I would trust it for 12 volt automotive. Maybe paint on a few coats? Maybe try a fancier finish like French tips?
    Wasn't there a recent RoadTest to do with testing insulation resistance? This would be an interesting test to add.
    -Nico
    shabaz over 8 years ago
    Hi Nico!
    Nice quick solution : )  Smells nice while it is drying too : )
    For higher power/mains systems it may be risky, as I understand it contains flammable stuff? I'm no chemist though : ) Maybe it is non-flammable when dry, since so many people stick it on their nails : )
    Good to see this idea for providing insulation. I wonder what other fast-drying paint-on coatings are easily available too.
