Nico teWinkel's Blog Sometimes it's not actually a glitch.
  • Author Author: ntewinkel
  • Date Created: 1 Dec 2020 1:57 AM Date Created
  • Views 1475 views
  • Likes 9 likes
  • Comments 14 comments
  • hummingbird
  • usb heater
  • feeder
  • wemos d1 mini
  • temperature
  • esp8266
ntewinkel
ntewinkel
1 Dec 2020
Have you ever had one of those moments where the data just looks out of place?
The above chart is from 2 temperature sensors. The one shown in green is connected to my hummingbird feeder (insulated, with a small USB-powered hand-warmer heater on it), and the other is hanging under the eaves to allow me to compare heater performance to outdoor temperature. It's set up using 2 Wemos D1 Minis with a few PHP scripts on the server side. It was a quick independent solution to get some quick data for my hummingbird feeder heater projects, so I expected some issues.
And the graph shows a sudden 3 degrees C dip in just 15 minutes from approximately 6:44 am to 7:02am!
In my case the above sort of graph glitch usually leads to digging a bit deeper and fixing some bugs. I thought maybe the power or WiFi was out for a bit, but the points actually show the gradual decline.
However, this time around it seems the weather had a glitch, not my project!
The last 24 hours of data from our weather office shows a sudden dip in temperature too (2.5 degrees C), along with a shift in wind direction (SE to NNW) and clearing up (as seen in the visibility and conditions columns). Their data only shows the rougher hourly increments, compared to my by-the-minute reports.
Interesting, to me anyway image
Also interesting and useful to me is the fact that the hummingbird feeder dropped rapidly in temperature too, even though it is insulated and heated... it's possible the heater didn't kick in during that time, or maybe I need a more powerful heater and better insulation.
I bought this little USB powered cup warmer for my next heater to try. Canadian Tire, for $15 CAD - that's about 1/3 the cost of a purpose-built hummingbird feeder heater. Seems expensive for a cup warmer, and probably not very effective for that purpose (just buy an insulated travel mug!), but it appears to be perfect for keeping hummingbird feeders frost-free in my climate!
Hope everyone is doing well and staying warm and safe out there!
Best,
-Nico
  • Gough Lui
    Gough Lui over 5 years ago +6
    We recently had a heatwave over Saturday/Sunday reaching 40+C. But a quick change of the winds caused a massive drop in temperature here too: Reality sometimes can surprise you! - Gough
  • colporteur
    colporteur over 5 years ago +4
    I'm surprised the birds stick around. Hummers usually leave early in our climate.
  • neilk
    neilk over 5 years ago +4
    Nice piece of analysis, Nico. I presume you have updated your graphing software to the new(ish) Google standards?? Mine stopped working a while ago and although I've looked at the new standards, I haven…
  • colporteur
  • ntewinkel
    ntewinkel over 5 years ago in reply to colporteur
    I was surprised too. I used to always put away the feeders in winter and then I read an article about Anna's hummingbirds that over-winter in my area (Vancouver Island, BC).
    As soon as I put the feeder back out we had birds taking advantage of them.
    Right now they still go through a cup of nectar every week or two.
    They stay all winter, through snow and freezing, so a local birders challenge is to keep the feeders liquid during our cold snaps. I'm looking for affordable solutions for other enthusiasts in my area.
  • colporteur
    colporteur over 5 years ago in reply to ntewinkel
    Aaah, your western climes affords you the opportunity for a little heat to go a long way. My location at the entrance to the prairie isn't as compatible.
    I wanted to winter my goldfish in the pond. A cattle trough heater was sufficient to keep the water open and a pump to deliver air below the surface was all that was needed. Feeding carp is not required when they are dormant, it can actually kill them.
    I sat to discuss my plan with a retired farmer. He believed it would work but offered some insight. If you lose power to the pond heater, would there be sufficient time to discover the outage before the fish were frozen. When the thermometer mercury drops below -40 degrees on both temperature scales it doesn't take long for things to freeze. Eight hours at work before taking the bus home would be sufficient to cube the ice.
    The fish winter in a basement tank and summer in the pond. So much for trying to accommodate Mother Nature as you have.
  • colporteur
