Ralph Yamamoto's Blog Adafruit DVI Breakout - with RPi-Pico
  • Author Author: ralphjy
  • Date Created: 6 Jun 2021 8:50 PM Date Created
  • Views 3295 views
  • Comments 5 comments
  • rpi pico
  • adafruit dvi breakout
  • rp2040
  • bit bang dvi
ralphjy
ralphjy
6 Jun 2021
I'd previously used a SparkFun RP2040 Micromod with a Big Display Carrier Board to try Luke Wren's Bit-Banged DVI RP2040 HDMI Display .
I saw that Adafruit had designed an inexpensive ($1.95) Breakout Board that would allow you to do this with any board that had the capability to drive the 4 differential signals required for DVI.  Adafruit DVI Breakout Board - For HDMI Source Devices .  Seemed like a fun thing to try with the RPi-Pico.
Here's a picture from the product page.
I started this post about a month ago when I received my DVI Breakout Board.  At that point, however, I couldn't get things to work.  The board had just come out and there wasn't a reference to how the demo was built.  I posted a query on the Adafruit Forum https://forums.adafruit.com/viewtopic.php?f=50&t=179072&p=876269#p876269  and I just noticed today that there were a few follow up posts.  And they did add a picodvi-test.zip example file to the product page.
I discovered the cause of my problem - I needed to edit a configuration file.
An excerpt from the readme:
Anyway, thought I should finish trying this out.
Here is a picture of my setup:
Notice that I've added a jumper to provide 5V for using this with TVs (see the Forum discussion).
And here is my proof of life video:
So, $1.95 well spent.  I'll need to figure out how to use this in a project...
  • ralphjy
    ralphjy over 5 years ago in reply to cstanton +3
    No, this DVI-D used on the HDMI cable. I haven’t used DVI-A for a long time. It was analog that was used with VGA displays and was not compatible with DVI-D. I think DVI-I cables supported both formats…
  • Gough Lui
    Gough Lui over 5 years ago +2
    That's pretty impressive considering the signal frequencies involved and the fact it's going through jumper wires and a breadboard. The fact that a small microcontroller can put out a DVI/HDMI-compatible…
  • cstanton
    cstanton over 5 years ago +2
    Being DVI over HDMI does that make it actually an analogue signal?
  • cstanton
  • cstanton
  • ralphjy
    I haven’t used DVI-A for a long time.  It was analog that was used with VGA displays and was not compatible with DVI-D.  I think DVI-I cables supported both formats.
