Ralph Yamamoto's Blog Genmitsu CNC 3018-PRO - becoming useful
  • Author Author: ralphjy
  • Date Created: 9 Aug 2019 5:46 AM Date Created
  • Views 10148 views
  • Likes 9 likes
  • Comments 24 comments
  • genmitsu cnc 3018-pro
  • cnc router
ralphjy
ralphjy
9 Aug 2019
I had a minor victory on my road to figuring out how to use my new CNC router.
I received the 0.5mm carbide end mills that I bought on Amazon and used one to successfully shorten a proto PCB that I need for my LoRaXes project.  The mill has about 4 mm of cutting depth.  The PCBs that I'm cutting are nominally around 1.6 mm thick.  Not a very impressive looking cutter but it worked.  I increased the spindle speed to 3000 RPM and reduced the feedrate to 80 mm/min and set the cutting depth to 0.15 mm per pass.
Here is the shortened PCB next to one that is uncut:
The cut edges are very smooth but you can see that they are not quite straight.  Not sure if I can improve that with tweaking or if that's the inherent limitation of an inexpensive router and cheap end mills.  Only time and experience will tell.  Anyway, I'm pretty satisfied with the outcome.  The tool did what I needed it to do.
  • Fred27
    Fred27 over 7 years ago +5
    Welcome to the world of CNC. It's fun, isn't it? You may know this already, but PCBs are particularly may to cut. They will blunt your endmills and the dusty is abrasive and nasty. For that particular…
  • Fred27
    Fred27 over 7 years ago +4
    I originally got a CNC mill (well, converted a mill myself) in order to mill PCBs. I ended up moving to etching as milling anything smaller than SOIC starts to get impractical. https://0xfred.wordpress…
    balearicdynamics over 7 years ago in reply to ralphjy +3
    The laser is controlled by PWM and there is a lot of relatively low power spindle and small diameter. The z-axis is not easy to be adapted (maybe with some 3D printed adjustment. The software I use is…
  • Fred27
    For that particular job I'd have used a beefier endmill - maybe 2mm or more. You'll get less flex and you're less likely to snap it. Actually, for that job I probably wouldn't have used a CNC mill, but I'm guessing you really want to find your way round your new toy!
    • Vote Up +5 Vote Down
  • ralphjy
    ralphjy over 7 years ago in reply to Fred27
    Hi David,
    You're right that this probably isn't the best tool to cut a PCB, but in my case I don't really have much else at home.  My Dremel has nice cutting wheels but I'd need to fixture it.  I'd love to get some more specialized tools but I don't do enough PCB work to justify it.  It was nice when I had access to a shear and bandsaw.
    In any case, I do need to get more experience.  I agree that I should have used a bigger endmill since I wasn't planning to use the other pieces of the PCB.  I just received a set of various sizes to try out.  I guess I was thinking that I didn't want to chew up the copper pads on the scrap pieces, but I need to get used to the mess a router makes (you can tell I don't do much machining or woodworking image).
    Do you have some favorite vendors for CNC accessories?
    Ralph
  • ralphjy
    Hi David,
    Ralph
