Ralph Yamamoto's Blog Laser Cutting at Community College
  • Author Author: ralphjy
  • Date Created: 6 Apr 2019 11:20 PM Date Created
  • Views 1157 views
  • Likes 13 likes
  • Comments 9 comments
  • maker-space
  • community college
  • laser cutting
ralphjy
ralphjy
6 Apr 2019
I've wanted to try using a laser cutter but haven't had the opportunity until today.  There is a campus of Portland Community College (PCC) just up the hill from me.  Spring term was the first time that they've offered Maker community education courses (3D printing and laser cutting).  I was fortunate to get into the first laser cutting class.  They have 3 laser cutters from Universal Laser Systems in their MakerLab.   They have a 60 Watt model with a work area of 32"x18"x9", a 30 Watt model with a work area of 24"x12"x9" and a 30 Watt model with a work area of 16"x12"x4".  They mainly work with wood and plastics and active ventilation is required to remove the smoke that is generated.  They don't have the capability to process metal.  The class that I took was a single 3 hour introduction to laser cutting but even with the queuing time we were each able to make a pre-designed LED "lantern" box and also a project that we designed ourselves.  The software that they use to design the projects is Adobe Illustrator.
Laser cutters
LED lantern box
You can see the good detail in the cutouts.  I was impressed by the ring around the planet.
Here is the bottom with the MakerLab logo engraved into the wood.  Engraving is done at a lower power level and it takes longer than cutting does.
There is a great website to design boxes and save them in the SVG format that can be imported into Illustrator.
https://www.makercase.com/
For my individual project I designed a "treat" box for my granddog.
I had a great time at the class.  I'm glad that PCC is creating new opportunities for the community to be able to access their maker equipment.  I'd really like to make some case designs for my electronics.  Maybe try engraving and cutting some acrylic panels.
    jw0752 over 7 years ago +5
    Hi Ralph, What a nice opportunity. There used to be a maker space in our little town but there wasn't enough population to support it so it folded and away went access to a laser printer. Every time I…
  • ralphjy
    ralphjy over 7 years ago in reply to fmilburn +5
    Hi Frank, The MakerLab is scheduled to have open access a couple of afternoons a week during the term. I'm going to have to give that a try. I don't have Adobe Illustrator, but I'm going to give Inkscape…
  • fmilburn
    fmilburn over 7 years ago +4
    Hi Ralph, That sounds like it was a lot of fun. Nice setup too. Are you able to go back and use the equipment? Frank
  • fmilburn
    Hi Ralph,
    Frank
  • fmilburn
    Hi Ralph,
    Frank
  • ralphjy
    Hi Frank,
    The MakerLab is scheduled to have open access a couple of afternoons a week during the term.  I'm going to have to give that a try.  I don't have Adobe Illustrator, but I'm going to give Inkscape a try.  It's a free alternative that should be able to generate SVG files that I can import into their setup.  They apparently don't allow you to bring in your own material due to safety issues but they seem to have a stock of soft wood and acrylic.  I'll need to check that out also.
    Ralph
    • Vote Up +5 Vote Down
