Ralph Yamamoto's Blog Laser Cutting at Community College
  • Author Author: ralphjy
  • Date Created: 6 Apr 2019 11:20 PM Date Created
  • Views 921 views
  • Likes 13 likes
  • Comments 9 comments
  • maker-space
  • community college
  • laser cutting
ralphjy
ralphjy
6 Apr 2019
I've wanted to try using a laser cutter but haven't had the opportunity until today.  There is a campus of Portland Community College (PCC) just up the hill from me.  Spring term was the first time that they've offered Maker community education courses (3D printing and laser cutting).  I was fortunate to get into the first laser cutting class.  They have 3 laser cutters from Universal Laser Systems in their MakerLab.   They have a 60 Watt model with a work area of 32"x18"x9", a 30 Watt model with a work area of 24"x12"x9" and a 30 Watt model with a work area of 16"x12"x4".  They mainly work with wood and plastics and active ventilation is required to remove the smoke that is generated.  They don't have the capability to process metal.  The class that I took was a single 3 hour introduction to laser cutting but even with the queuing time we were each able to make a pre-designed LED "lantern" box and also a project that we designed ourselves.  The software that they use to design the projects is Adobe Illustrator.
Laser cutters
LED lantern box
You can see the good detail in the cutouts.  I was impressed by the ring around the planet.
Here is the bottom with the MakerLab logo engraved into the wood.  Engraving is done at a lower power level and it takes longer than cutting does.
There is a great website to design boxes and save them in the SVG format that can be imported into Illustrator.
https://www.makercase.com/
For my individual project I designed a "treat" box for my granddog.
I had a great time at the class.  I'm glad that PCC is creating new opportunities for the community to be able to access their maker equipment.  I'd really like to make some case designs for my electronics.  Maybe try engraving and cutting some acrylic panels.
    jw0752 over 6 years ago +5
    Hi Ralph, What a nice opportunity. There used to be a maker space in our little town but there wasn't enough population to support it so it folded and away went access to a laser printer. Every time I…
  • ralphjy
    ralphjy over 6 years ago in reply to fmilburn +5
    Hi Frank, The MakerLab is scheduled to have open access a couple of afternoons a week during the term. I'm going to have to give that a try. I don't have Adobe Illustrator, but I'm going to give Inkscape…
  • fmilburn
    fmilburn over 6 years ago +4
    Hi Ralph, That sounds like it was a lot of fun. Nice setup too. Are you able to go back and use the equipment? Frank
  • ralphjy
    ralphjy over 6 years ago in reply to 14rhb
    The focal length of the lens is 2", so it is a fair distance from the material being cut.  The cutting does generate a quite a bit of smoke (at least with wood).  I should have tried to get a video with my phone.  The instructor said that they have to clean the smoke residue off the lens assembly at least daily because the laser can heat the deposited residue and damage the lens.  Seems like they would have made this process easier but at least it's only a few non-captive screws (they do it over a sheet of paper so dropped screws don't get lost).
    I've seen some articles about trying to make PCBs using a laser cutter.  It seems that copper is a difficult material to use with a laser cutter because of its thermal conductivity and reflectivity.  I do see FR4 listed as a material that can be cut.  We used to make quick prototype PCBs on a small CNC mill.  You've probably done that also.  That's probably still the tool of choice although it makes quite a mess.
    Ralph
  • 14rhb
    14rhb over 6 years ago in reply to ralphjy
    Good luck with the future project - I'll keep a watch out for any blog you make on it. The use of colours in the CAD to translate to cut depths makes sense, and I guess you canalso  keep the head up off the work unlike a 3D printer as the beam probably doesn't diverge much...the benefit being you can keep it clear from splattering (wood resins, molten plastic particles etc). I'm now thinking you could perhaps make a PCB on there?
    Rod
  • ralphjy
    Hi Rod,
    I actually do have a project that I'd like to cut a case for.  I'm working on a Snips interface to control an ipcamera (I currently use Alexa).  I've been having issues with my 3D printer but that's fodder for another blog post.
    The laser has settings for pulse frequency (pulses per inch, PPI) and power (percentage).  The drawing program assigns settings by color so in this instance black was set to cut through and red to do the engraving.  Reasonably intuitive to set up but as with a 3D printer you can do a lot of tweaking.  If you get the settings wrong there's a lot of smoke and sometimes fire.  I think that's why they restrict materials that are used until they can thoroughly vet them.  With these cutters the height calibration was mechanical (against a standard "post") not optical.
    Ralph
    genebren over 6 years ago
    Very cool!  I wish that I could find a similar program/class in my area.  I will have to start looking around and see what I can find.
    Gene
  • ralphjy
    ralphjy over 6 years ago in reply to jw0752
    Hi John,
    The instructor mentioned that I might be able to get access to a CNC machine in an adjacent lab.  I'll need to talk to the person responsible for that lab.  I'd love to be able to cut aluminum panels.  I probably shouldn't get carried away but it's feels nice to have discovered another resource nearby.  The granddog loves to walk up there but dogs aren't allowed on campus anymore.
    Ralph
