Ralph Yamamoto's Blog MAX78000FTHR with 2.4" TFT FeatherWing
  • Author Author: ralphjy
  • Date Created: 20 May 2021 2:58 PM Date Created
  • Views 2742 views
  • max78000
  • 2.4" touch screen
  • tft_featherwing
  • 320x240 lcd
  • max78000fthr
ralphjy
ralphjy
20 May 2021
The nice thing about using a Feather compatible footprint is that all of the FeatherWing accessories are available for use.  It would be great to integrate a small display with the MAX78000FTHR to create a portable smart camera.  A stacking display can't be used because it would block the camera and stacking displays don't have very high resolution or appropriate aspect ratio.
Adafruit makes a couple of nice TFT FeatherWings that would mount the MAX78000FTHR on the back which is the perfect setup.  There is a 2.4" 320x240 Touchscreen and a 3.5" 480x320 Touchscreen.  I opted to get the smaller one https://www.adafruit.com/product/3315 .
Here's a couple of pictures from the Adafruit product page that shows the display with an ESP8266 Feather mounted on the back.
And here's my setup.  The MAX78000FTHR board is longer than a standard Feather in order to accommodate the stereo audio in/out jacks.
I printed a cover to facilitate using this setup as a portable smart camera.  For this purpose, the audio jacks just get in the way.  It would have been nice to have a version of this board in the shorter Feather form factor.
I was surprised at how tiny the VGA (640x480) camera is. It's about 3x3mm - you can see it at the left center of the board.  Here's a link to the sensor https://www.ovt.com/download/sensorpdf/46/OmniVision_OVM7692.pdf .
I need to try a program that utilizes the camera and display on the MAX78000FTHR.  Most of the AI examples are for the MAX78000EVKIT  that uses a larger 3.5" TFT that is included on the board.  I've been having some issues with the MAX78000 SDK and the OCD debugger, but I compiled and ran the TFT_Demo shown in the video.
Hopefully, will get an AI example running with the camera and display soon - it looks like there is one available for MNIST.  Then I should be able to figure out how to program the camera.
  • DuvalFortes
    DuvalFortes over 2 years ago
    Hi All;
    im working with MAX78000FTHER with an Adafruit featerwing V2, with eclipse on windows, my code is compiling without any error , i just want do an tft_Demo application but its not work, plase check my code below and sent me some feedback.
    i put some printf and im using the eclipse terminal output to check if the code is working and receive this output, but the display remains blank
    * Copyright (C) 2022-2023 Maxim Integrated Products, Inc. All Rights Reserved.
    * (now owned by Analog Devices, Inc.),
    * Copyright (C) 2023 Analog Devices, Inc. All Rights Reserved. This software
    * is proprietary to Analog Devices, Inc. and its licensors.
    * Licensed under the Apache License, Version 2.0 (the "License");
    * you may not use this file except in compliance with the License.
    * You may obtain a copy of the License at
    * www.apache.org/.../LICENSE-2.0
    * Unless required by applicable law or agreed to in writing, software
    * distributed under the License is distributed on an "AS IS" BASIS,
    * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
    * See the License for the specific language governing permissions and
    * limitations under the License.
    * @file main.c
    * @brief TFT Demo Example!
    * @details
    /***** Includes *****/
    #include <stdio.h>
    #include <stdint.h>
    #include <stdlib.h>
    #include <string.h>
    #include "board.h"
    #include "mxc.h"
    #include "icc.h"
    #include "mxc_device.h"
    #include "mxc_delay.h"
    #include "utils.h"
    #include "state.h"
    #include "keypad.h"
    #include "led.h"
    #include "pb.h"
    #include "tft_ili9341.h"
    #define TFT_BUFF_SIZE 32 // TFT buffer size
    void TFT_Print(char *str, int x, int y, int font)
    printf("TFT Printing....\n");
    // fonts id
    text_t text;
    text.data = str;
    text.len = 20;
    MXC_TFT_PrintFont(x, y, font, &text, NULL);
    void TFT_Feather_test(void)
    area_t _area;
    area_t *area;
    char buff[TFT_BUFF_SIZE];
    printf("Init TFT Feather Teste....\n");
    MXC_TFT_SetRotation(ROTATE_90);
    MXC_TFT_ShowImage(0, 0, (int)&img_1_rgb565[0]);
    MXC_Delay(2000000);
    MXC_TFT_SetBackGroundColor(RED);
    area = &_area;
    area->x = 10;
    area->y = 10;
    area->w = 200;
    area->h = 100;
    MXC_TFT_FillRect(area, GREEN);
    MXC_Delay(2000000);
    MXC_TFT_ClearScreen();
    MXC_TFT_Line(10, 10, 200, 200, NAVY);
    MXC_Delay(1000000);
    MXC_TFT_Rectangle(10, 10, 200, 200, NAVY);
    MXC_Delay(1000000);
    MXC_TFT_Circle(100, 100, 50, PURPLE);
    MXC_Delay(1000000);
    MXC_TFT_FillCircle(100, 100, 50, PURPLE);
    MXC_Delay(1000000);
    MXC_TFT_SetBackGroundColor(BLACK);
    MXC_TFT_SetForeGroundColor(WHITE); // set chars to white
    int main(void)
    // Wait for PMIC 1.8V to become available, about 180ms after power up.
    MXC_Delay(200000);
    printf("Hello Main....\n");
    /* Enable cache */
    MXC_ICC_Enable(MXC_ICC0);
    /* Set system clock to 100 MHz */
    MXC_SYS_Clock_Select(MXC_SYS_CLOCK_IPO);
    SystemCoreClockUpdate();
    /* Initialize TFT display */
    MXC_TFT_Init(MXC_SPI0, 1, NULL, NULL);
    while (1) {
    MXC_Delay(200000);
    printf("Hello While....\n");
    TFT_Feather_test();
  • DuvalFortes
    Hi All;
    * @file main.c
    * @details
    #include <stdio.h>
    #include <stdint.h>
    #include <stdlib.h>
    #include <string.h>
    #include "board.h"
    #include "mxc.h"
    #include "icc.h"
    #include "utils.h"
    #include "state.h"
    #include "keypad.h"
    #include "led.h"
    #include "pb.h"
    // fonts id
    text_t text;
    text.data = str;
    text.len = 20;
    area_t _area;
    area_t *area;
    MXC_Delay(2000000);
    area = &_area;
    area->x = 10;
    area->y = 10;
    area->w = 200;
    area->h = 100;
    MXC_Delay(2000000);
    MXC_Delay(1000000);
    MXC_Delay(1000000);
    MXC_Delay(1000000);
    MXC_Delay(1000000);
    int main(void)
    MXC_Delay(200000);
    /* Enable cache */
    while (1) {
    MXC_Delay(200000);
    TFT_Feather_test();
