Feedback and Support
F&S Forum Related products widgit not updated to show stock avaliable
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Fri, 02 Jan 2026 12:01:46 GMT ETag: "0x8DE317E31FF1C26" Set-Cookie: .te.csrf=funyafcG8i7p6g03RAtvQpew3Yo5B_etxorDqfoYq5I; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_FyCYKlv7eWmcbN7aWDhCcIASz8hRvRAJEEeawqWg9msfFJMbfMO6ppca1516KsT5DCGObmIHSeBZu08RH0EXzJ5w4lcIn%2bDwdlYHA2hRjhpJ5AK45QjRIRteJMMGhQKhLNjhBo%2bwPLrclike%2bJiOpJ9lIMJa6BOVmSUyhgcTZrgichGAqClWwTRh5umogaspUc5D4jQ4OrOwdJTsbmjLTnZRRi%2bsOTua212MR19wLGIJLAM7vHgUGlwTx9i4UgPBmDOU3v5lTJFRxISrYCrK%2fA%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=99 Server-Timing: origin; dur=44 Server-Timing: ak_p; desc="1767355306515_34604952_338504855_14317_5468_6_8_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Subscribers 15 subscribers
  • Views 852 views
  • Report Bug
bwilless
bwilless over 3 years ago
On the Azure Sphere Place page, there is a widget showing a buy button and stock status for the Avnet Azure Sphere Starter Kit.  The widget shows zero stock.  In reality, we have lots of stock.  See this link.  The widget should show that we have stock of this item.
Brian
No stock screenshot from this url.
Actual Stock from this url.
  • cstanton
    cstanton over 3 years ago +1 suggested
    The product links by default link to Farnell, Newark and element14 APAC. The link you're providing is on the Avnet store. As you're based in America, the product link will be linking to Newark for you…
  • cstanton
    0 cstanton over 3 years ago
    As you're based in America, the product link will be linking to Newark for you, which it is correct that it is currently available for back order:
    https://www.newark.com/avnet-engineering-services/aes-ms-mt3620-sk-g-2/azure-sphere-mt3620-starter-kit/dp/71AJ7487
    That widget only supports Farnell, Newark and element14 APAC product codes/SKUs as the element14 Community is mainly a part of Farnell.
    I will have to raise it with the development team to support Avnet SKUs.
    We can also workaround this by putting a custom widget on the page with a buy now button that works for Avnet.
