I completed the webinar and got the certificate but the certificate doesn't have my name instead it has deleted deleted
Hi Dipace , I was able to login to your community account as the user that started this thread and that user did not meet the requirements to earn certification. This was also confirmed when I looked in the backend of on24. Did you delete your community account after you attended the webinar? That would explain why it says deleted on your certificate.
Login to the community and go to the webinar page here:
Machine Vision with the Kria KR260 Robotics Starter Kit
If you click on the green button you can see if you have met the minimum requirements for a certificate (pass a test, watch 30 mins of presentation):
Try using this method and you should be able to get your certificate when you meet the criteria
