Feedback and Support
F&S Forum video playback issue
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Thu, 01 Jan 2026 12:42:18 GMT ETag: "0x8DE317E31FF1C26" Set-Cookie: .te.csrf=z_Z1EVZGETM7EriDp_6tyNblMFQ_zrZ3emDeU0_vyIj0; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_Vy5dU0Ie4zomELym5d92Xf%2bsXFUsI5wRS6Y78Sh1fLG27WwPCDAPiFm%2f2F%2bTVkZS4Bz%2bb0WKDTG8n4hPoJTCheW7Uel%2bUtcerpkqxle0KH4Z8Th4Wggsm%2fPY1TaL7%2biWSiwd%2fcqGCwtftWJgnAc%2bwIlAekTleyLjwC5ag23XDUlVDKgiF5VpxVXDaxug6ih1bfHfR9x3ngZpZ2DJN%2bMRmxYsAp1ZS3RRyz5xptPXCKpmI2fny1NLrhYsVdCrtrapgKUqUn%2fPJ74ht82QFikPbg%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=36 Server-Timing: origin; dur=49 Server-Timing: ak_p; desc="1767271338521_34604952_305520162_8454_5770_8_8_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Subscribers 16 subscribers
  • Views 185 views
  • Report Bug
Jan Cumps
Jan Cumps over 2 years ago
I could see the video in this post yesterdays. Today I get an error:
Error:
This video is either unavailable or not supported in this browser
Error Code: MEDIA_ERR_SRC_NOT_SUPPORTED
Technical details :
The media could not be loaded, either because the server or network failed or because the format is not supported.
Session ID: 2023-12-04:9a46b622b24522c28da6854a Player Element ID: vjs_video_3
  • cstanton
    0 cstanton over 2 years ago
    HI Jan Cumps ,
    That's weird, I can see the video when I load the page, so there could be a few reasons for that.
    Can you try viewing the page with a private window or incognito window to see if you have the same problem please?
  • cstanton
    HI Jan Cumps ,
