Feedback and Support
F&S Forum Project "Updated" Date shows when draft was created rather when it was published
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Tue, 20 Jan 2026 17:20:19 GMT ETag: "0x8DE317E31FF1C26" Set-Cookie: .te.csrf=X5BS-c57okkB5TkQ2Cjf_9Jawhp2STLnMSYhoaRRy1w; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_hRwBrK02yqbFa4YqJuRedsKMokVCFkTC1hydZPWcdPjAoRkfdr9iHYOEaW4ZXh7B2OfZSVJ02ajL5%2bOMbHY6O5%2b2EOkZMuh%2fqCjyiVJbo3veLCo%2fXFLxw2a1EEwJXUJleAjxZe15t69AM1ijbkXiak9xFDKP6K8X963jHETJ6e5mWDzznauH5R3RHh45OFWRjI2N2CL41G%2fnFtnaFUZSCBi%2bS6clLzTw0NxjAvdUJF%2fOvxAkusOVEUu1frTMx2r8R%2bHmoJHwy74Hm9EvUHU7VQ%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=32 Server-Timing: origin; dur=56 Server-Timing: ak_p; desc="1768929619428_34864915_32699698_8781_5218_7_8_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Subscribers 18 subscribers
  • Views 54 views
  • RoadTest
ralphjy
ralphjy 2 months ago
I just published my project blog for the In Reach! Challenge https://community.element14.com/challenges-projects/design-challenges/in-reach-ultrasonic-sensor-sensing-challenge/a/projects/PR113/echo-park---ultrasonic-parking-assistant.
The "Updated" date is showing the date the draft was created rather than the published date.  Is there something I need to do to get the correct date?  Confused me at first because it wasn't at the top of the list when I went to verify it showed up.
    0 dougw 2 months ago
    If you edit the blog and select the "Options" tab it allows you to specify the publication date.
  • ralphjy
    0 ralphjy 2 months ago in reply to dougw
    The publication date is correct.  Or does Options allow changing the creation date also?
    That is what is showing in the list and does not change when I published edits.  The publication date did update with edits but I did not look at the Options..
    0 dougw 2 months ago in reply to ralphjy
    You have to manually adjust the date - which will place your blog in its new chronological position on the forum, based on the date you enter.
  • ralphjy
    I realized some of my confusion, the Project editor does not have the Options Tab that was available in the regular Blog editor.  I remember being able to change the Publish date of regular blogs, but again it appears that the Updated date in the Projects list is the created date not the published date.  If you look in the black banner that I included above - that is the last time I updated the file (I had to edit and re-publish a couple of times because of errors in the formatting of the ToC).  It has the correct publish date of 13 Nov - it just doesn't use it in the Project list on the site home page.  It actually does show the correct date on the Challenge Project page, so I guess I won't worry about it.
