Feedback and Support
Site Announcements and Status Problem creating content: Rich Text Editor takes 24+ seconds to load or doesn't load fully
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Fri, 13 Mar 2026 05:04:15 GMT ETag: "0x8DE62FB5D5EDB64" Set-Cookie: .te.csrf=-xAAroeL7waRYPwCnmyr1LZXhIV-4WFSDJOujlik0As; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_NBcHXlrzM2oiD7Okgt9N8%2fUml80Zp2sm%2bhrUWat5S%2fJJTjeP0yJGtZkmTRNOyQKJLpPuNIJGYUd51hSDe6MjopY2dggpY%2fWjIdHoT%2f8ovhwLAuwSzR3Pdms0YBzqVWG%2fnXFa6xFxe6EW9McbRDaiBQc8SFHCPh4Jnk4PRfc8qOTt0yUZOmQBb4NEQejTLrexItQFrG7VDN51zlWQGrxB7P%2bOOripVBoMmVEuPpp%2fXb6dpSMw6Hm4PYoXjvxau2w33lRV%2fMnBFvvWoWLvXCGAkw%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=31 Server-Timing: origin; dur=46 Server-Timing: ak_p; desc="1773378255263_34604952_103311196_7708_5746_6_8_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 1267 views
  • slow
  • rich text editor
  • content
  • rte
cstanton
cstanton over 3 years ago
Currently there's an intermittent problem with the site where creating content fails to load the rich text editor. It takes 24+ seconds to load as it's hung up / delayed or waiting.
For example:
Is missing this:
This has been reported to the site admin team, and may be a problem that happens sometimes, but not always.
It may affect more content than in the screenshot.
Previously reported similar issue:
/members-area/support/f/forum/51183/problem-with-creating-blogs-with-edge
  • cstanton
    cstanton over 3 years ago +1
    If you experience this problem, or one similar to it (for example not receiving notifications when you're meant to) please make a post in Feedback and Support with your timezone, date and time when you…
  • cstanton
    The server admin' has restarted the Verint jobs server which should alleviate this problem, but the root cause hasn't been discovered so it may happen again.
  • cstanton
    cstanton over 3 years ago in reply to cstanton
    To clarify it is helpful to know when this does happen, if you're unable to report it on the element14 Community via Feedback and Support, please reach out to us on Facebook or Twitter, or to me directly on Twitter.
  • cstanton
    If you experience this problem, or one similar to it (for example not receiving notifications when you're meant to) please make a post in Feedback and Support with your timezone, date and time when you've experienced the problem so that the server admin can investigate the logs as to the cause of the problem.
