Feedback and Support
Site Announcements and Status Solved: Redirects from www.element14.com/community to community.element14.com are broken
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Mon, 19 Jan 2026 23:15:58 GMT ETag: "0x8DE317E31FF1C26" Set-Cookie: .te.csrf=QP4Mnr0_Zu0FlqcydZH2hxHD3FoMRT5R62sNTRh-URM; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_Rr7JtPDFydfz7O7TNdVkw3YZWq4iqpHdMNMJZPgmktmLqJlBLYEvasBaZtI%2fIeu6Sd6xuAkUx9AbO85XAVMs4N2VntUSEXcb1mQa3HyzrorC3x1eCjNbL%2ffQWkDslysF4xauEY8Wo6iyMNILWThtZlsSWVOXrE%2bOn%2bZLEET1PtRGc0Ecpcbn10WWtBePlkhT8LFcfmPXH%2f97v7FpVX%2b0YKMSaSKoavFfAKh0Ue8Z5hlRzPvky4597hVp3REFVE9EbOavTyBpleONynvqpQiX%2fA%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=47 Server-Timing: origin; dur=51 Server-Timing: ak_p; desc="1768864558090_34604952_349728886_9780_5334_7_23_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 523 views
  • rewrite
  • verint
  • old links
  • jive
  • redirect
cstanton
cstanton over 3 years ago
At the moment if you have any links redirecting from the old Jive site (https://www.element14.com/community) through to the new Verint site (community.element14.com) they may not work.
We're aware of the issue, and we do not have a full rewrite map setup because of the sheer number of links from the old Jive domain to the new Verint domain, and for what redirects are in place, relies on the older server(s) at present, which have a poor uptime.
The server administrator's aware, and there's a Jira ticket in with them to resolve this, I do not currently have a timeline for when this will be fixed, the new rewrite mapping will be setup in our CDN/Caching services of Akamai.
  • cstanton
    The redirects are currently active again.
    Work to have these migrated to Akamai are still ongoing and there may be further outages.
