Feedback and Support
Site Announcements and Status Resolved: Unable to '100%' or Complete a Quiz
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Sun, 18 Jan 2026 02:43:23 GMT ETag: "0x8DE317E31FF1C26" Set-Cookie: .te.csrf=VUuZsVDhaJIb7Eaf3zKQtx6AItPCv4xE5vKtDqCO3qY; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_smBApZ3TnmVR%2fCxCCapyH4bknbwkd8s%2f98HcHcdVmtGvm7Yr7kHqk6RsOOGhv2JKvBDZhRq5oeRC2WxqqwtzH3m3MnsA7nN3bccV%2bADtPZGC6BJY%2bmrAJ6skJuOEGi3urWNVliC2DfKw2qxp%2bU1nI%2bWamty6v2NwpiQ461V6x9s2DQb%2fudkYTAuq%2fzzZSUsdc7%2biyRFAHmQR1zOR%2fvDS8YSmpSYk336cYUenfaNHyyfL3nlSD1TdrjONrbAwfjuWW28Gg2I62zJMOCh7fsos9Q%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=32 Server-Timing: origin; dur=49 Server-Timing: ak_p; desc="1768704203053_34864915_1085627060_8026_6417_7_9_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 680 views
  • essentials
  • quiz
cstanton
cstanton over 2 years ago
There's a known issue that's currently being investigated by the development team whereby you'll select the correct answer(s) for a quiz, and then be unable to achieve 100% because of a silent (or visible) error, but not be notified if a question was marked as 'incorrect'.
We currently do not have a timeline for when this may be fixed.
  • cstanton
    Unfortunately our development team have been unable to reproduce this issue.
    They are investigating different testing methods in an attempt to replicate it.
    If you experience this problem, please get in touch to provide a .har file from the browser's dev' tools when you experience the problem.
  • cstanton
    cstanton over 2 years ago in reply to cstanton
    Changes were made to the way in which Quizzes are done, there is still a known problem with receiving points.
    Tracking of this issue has been superceded by  Known Issue: Downloading eBooks, Applying for Design Challenge / RoadTest and Quizzes
