Feedback and Support
Site Announcements and Status Unplanned Maintenance: Quizzes, RoadTest Applications and Design Challenge Applications
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Fri, 27 Mar 2026 09:58:11 GMT ETag: "0x8DE62FB5D5EDB64" Set-Cookie: .te.csrf=YbNmOrKvnn3srOghjgy7_bVLPKjuKwrwXS8G1H2tNjA; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_oWQCL1OTXMRSVkZE52F8vNKdCwnOjRWnjWhJSA7Wi2Zm6OHTzDPj9UB9ai4XHyiV0gxunErvJTUgKnbyNs7xjajSvrNTPKSu5XLaRr9lkWv1ZBlML4RFH8kBQvzdnxkQBn6wIPe3GIIlqUt%2bqBicaJ3%2bJFPdELJSUqY03oIi%2biYXXB87LelJtxkVW%2b3%2bFqcNPibfmZUHwAugGTOX%2fdBoPibygsbQVJTh%2bW7alCi0DrAhTGvh8GsQPgcFRRYmuMYLvFZ%2fR7A%2fokrICMjDwxGwcA%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=43 Server-Timing: origin; dur=46 Server-Timing: ak_p; desc="1774605491647_34604952_4007226407_8854_7338_5_16_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 378 views
  • RoadTest
  • design challenge
  • essentials
  • quiz
cstanton
cstanton over 2 years ago
The server that is used for quizzes, roadtest applications and design challenge applications is down for unscheduled maintenance. This should only take 10 minutes, but may take longer if there's unforeseen work that needs to be done.
The development team apologises for the short notice.
19th July 2023 - 16:07 BST
  • cstanton
    This was completed but will require to be taken offline again.
     Unplanned Maintenance: Quizzes, RoadTest Applications and Design Challenge Applications Part 2
