Documents ZX2051 AM/FM Radio Receiver Kit Documentation
  • Author Author: shabaz
  • Date Created: 7 Jul 2019 3:17 PM Date Created
  • Last Updated Last Updated: 22 Jun 2021 12:22 PM
  • Views 5072 views
  • Comments 17 comments
The ZX2051 is a low-cost kit to build an AM/FM radio receiver. I thought it could be fun for kids to assemble. The instructions are in Chinese, so the purpose of this blog post was to document any information needed in English (or other languages) to successfully build it.
Any translations, or advice, is welcome, since I cannot do this entirely on my own : )
Original Documentation
Since I don't have the copyright to it, I've saved high-res scans of the ZX2051 documentation on a third party server during the time that collaboration is needed, but will remove the link after it is no longer required to act as the only documentation.
There are low-res copies of it here (might not be readable), which I believe is fair use.
Translation Attempt #1
Google Lens was attempted, with some success and some amusement. It didn't get the translation entirely right I think : )
Another attempt was only slightly better:
One more time..
PCB Layout and Notes
The scan here shows the copper side PCB layout, with some of the important bits highlighted in red.
From what I can tell using Google Lens to do the translation, the quadruple tuning/variable capacitor needs the end with the two wires to be inserted in the red highlighted hole, because one side of it contains the FM capacitors (lower capacitance) but the side with the two wires that insert in one hole, is the AM side (higher capacitance).
Also, T2 is highlighted with a red square. T2 is the metal can with the core that is painted red.
For the electrolytic capacitors, the hatched/shaded side of the circles in the diagram above is the negative end.
To be continued..
More info to follow after this kit has been soldered!
  • fm radio
  • zx2051
  • electronics kit
  • radio
  • am radio
  • electronic kit
    shabaz over 7 years ago in reply to jw0752 +6
    Hi genebren and jw0752 , We managed to solder all the resistors, and some of the ceramics today : ) The 8-year old was trained by showing him how to solder one resistor to scrap PCB, and then he tried…
    genebren over 7 years ago +5
    Shabaz, The translations are quite amusing. Not sure how the 'prisoners' helped with the circuit or why it is necessary to go to a liberal arts school in order to receive the broadcast, or how this effects…
    jw0752 over 7 years ago +5
    Hi Shabaz, My experience has been that there is usually enough information between the bill of materials which has some information in English (part # and Value) and the screen printing on the board to…
    Hi Shabaz,
    My experience has been that there is usually enough information between the bill of materials which has some information in English (part # and Value) and the screen printing on the board to build the board. The rest of the build info has to come from the schematic. Don't be surprised if there are mistakes in any of the 3 sources of information. the fun and the challenge comes from having to apply common sense and your electronic experience to solve the informational conflicts.
    • Vote Up +5 Vote Down
    The 8-year old was trained by showing him how to solder one resistor to scrap PCB, and then he tried one resistor on the scrap board too.
    Then, he did the soldering and wire-clipping by himself, with me and his younger brother (6-year-old) assisting by searching for the component references. I did the resistor identification, and the 6-year-old did the number reading off the tiny through-hole ceramics. The 8-year-old is now confident pushing in the parts, using blu-tack to hold things down, and cleaning the iron and soldering : )
    The safety specs are too big, we need to find kid-sized ones. He's also now aware what a resistor looks like ("long stick with plastic in the middle") and capacitors too ("round with two sticks") and eventually figured out for himself that R and C referred to them : )
    The 6-year-old too was trained on a single resistor, but he's not had a chance to do any more yet.
    This will be a multi-week project I think! since they only have a few hours to spend each week. So we're predicting it will be finished in week 3 or 4.
    • Vote Up +6 Vote Down
    genebren over 7 years ago in reply to shabaz
    shabaz,
    That is some pretty good lead forming and soldering.  Looks like you have some fast learners there.
    Enjoy!
    Gene
  • fmilburn
    fmilburn over 7 years ago in reply to shabaz
    Hi Shabaz, it is looking great!  They are going to be really proud of it when they finish. I haven't let my 8 year old grandson solder yet - but it seems it is time to learn.  I will be on the lookout for kits, and may order the radio kit as soon as you pioneers have demonstrated how to build it.
  • fmilburn
