Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11176 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
  • mahmood.hassan
    mahmood.hassan over 6 years ago
    My recent worst experience is soldering of XT-60 connector with li-po battery. My usual soldering iron suddenly stopped working (heating element issue and waiting for replacement) so as a quick replacement I bought this low cost Chinese XXXX soldering station iron from local market and when I tried to solder the connector its heat was not enough to melt the solder. After spending lots of time on single connector I disassemble the soldering iron to check why its not providing enough heat and found out that heating element is cheap Nichrome one so I decided to break the the outer shell and then decided to directly use the coil as heating source for the soldering of that connector.
    Cheap Chinese soldering station iron's Nichrome heating element with K-type thermo-couple (with broken ceramic outer-shell).
    Turned on soldering iron
    After lots of trouble, I was finally able to solder the XT60 connector with li-po battery but it was looking horrible. But for the time being I was happy that it was soldered with battery and I can test the rest of the hardware.
    My worst soldering experience ever.
    • Vote Up +8 Vote Down
  • ninjatrent
    ninjatrent over 6 years ago in reply to mahmood.hassan
    The XT60 lipo battery connectors are a real pain to solder. The large gold-plated terminals and copper wire can act as heatsinks, making it difficult to melt the solder. The plastic connector prefers to melt before the gold-plated terminals and wire are at temp for the solder to melt. Your results look much better than my previous attempts.
  • mahmood.hassan
    mahmood.hassan over 6 years ago in reply to ninjatrent
    Yes it is difficult to solder but with right soldering iron (higher power) and right tip it is not a very difficult thing to do.
    All this happen because I mysteriously lost heating element of both of my soldering iron in that week so this was my quick alternate solution.
    At the end I was able to solder it but it took too much time and looks horrible.
  • mahmood.hassan
  • ninjatrent
    I agree with you. It requires a higher temp of the soldering tip. I have had recent success with a Hakko soldering iron and Hakko hoof-type (bias cut) soldering tip. It provides enough surface area to heat the large gauge wire and lipo battery connectors. As you have experienced, my work is not beautiful to the eye but the solder joint has good contact and mechanically sound. Heat-shrink wrap does well in masking these blemishes. This type of large gauge wire requires a bit of finesse to solder. The lipo battery that I had purchased did not have the correct XT60 connection that my application required. In the future I will search for a battery with the appropriate connection.
