Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11364 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
  • koudelad
    koudelad over 6 years ago
    Me and my friends (at the age of 12) built a small circuit with an 741 Op-Amp on a universal PCB. It was supposed to light an LED if an input voltage was above some level.
    In the field we found out that there was one wire connecting two pads instead of another pads. We had no soldering iron, so we held a metal nail in pliers, heated by a cigarette lighter.
    We managed to somehow desolder the wire, but we were not able to use the setup to solder the wire to a different location again image The insulation of the pliers was damaged by that procedure, of course...
    • Vote Up +7 Vote Down
  • station240
    station240 over 6 years ago
    The worst tool to use for grip the head of a stripped out screw is a pair of cheap side cutters.
    It's not a bad idea because it doesn't work, it does.
    It's not a bad idea because it chips the cutting surface, it does but it's a cheap/worn out tool anyway.
    It's not a bad idea because the blades aren't intended to be lodged between the screw head and washer
    No, It's a bad idea because cheap metal fractures easily, one of the blades will just fall off leaving you looking stupid and wondering what to do now.
    Yes I was desperate, there was one screw left and this thing needed fixing. Already broken one other tool trying to get it out, should have known better.
    It's not a cheap tool if it's the only one you have.
    • Vote Up +8 Vote Down
  • 14rhb
    14rhb over 6 years ago in reply to blkpag1
    I've never seen that before blkpag1 so thanks for sharing. Glad to see the guy in the red shirt had a hardhat on for this operation. Maybe the lifting bolts were only rated at the dead weight rather than the loading due to the helicopter's down draft?
    What do you reckon the mainbeam pattern looked like afterwards image
    • Vote Up +6 Vote Down
  • blkpag1
    blkpag1 over 6 years ago
    Worst tool to use to move a satellite dish (30 foot diameter uplink) would be a helicopter.  Several years back I worked for Learfield Communications as a broadcast engineer.  Several years prior to me starting, the Chief Engineer that I worked for had to move the satellite uplink to the new location.  They got the idea to move it by helicopter to reduce the down time instead of having to completely take it apart to move it by truck..  The move started off fine, but quickly went south fast.  Turns out the hardware used to lift the dish was defective.  The dish dropped from several hundred feet to the ground.  It destroyed the dish.  Luckily since there were multiple journalists around being a news network, it was all captured on film.  It has since been uploaded to youtube and for many years the Chief Engineer had one of the failed bolts mounted and on his office wall.
    https://www.youtube.com/watch?v=DzdiFyF_kIc
  • colporteur
    colporteur over 6 years ago
    My story is about a cable cutter tool, similar to the one shown in the picture, being used to cut armoured cable shown in the insert. It is the WORST tool for the job given the conditions.
      The job required the removal of ten obsolete equipment racks from an equipment room. The equipment room was still live and contained some equipment in service. The racks to be removed were wired to 20 amp circuits in the breaker panel using armoured cable from the rack to the panel. The cables to be removed were located under infinite access flooring. The cables had been tested and clearly tagged. image
      To speed up the equipment rack removal the power cable and all rack cables were to cut as it came up out of the floor. The cable under the floor could then be pulled back and removed by a crew working under the floor.
      Five racks had been removed using the above process. On the sixth rack the blades of the cutters cut through a cable that still had AC power. The power for that rack had not been turned off at the power panel.
      The arc caused by the blades cutting into the hot cable carved a pit in the cutters that you could pass a 12 gauge wire through. The spark and the noise startled the individual cutting the cable. As luck would have it, he was not hurt.
      A new individual had joined the crew. He was responsible for testing and tagging the cables. He became distracted when shutting off the breakers and apparently missed one. When asked about the breakers before the rack removal started, he confidently confirmed all breakers for power to the racks had been turned off.
      The individual that was on the sparking end of the cable wanted to take the guy out back and lay into him. The omission may have been overlooked but it was recalled that during the site safety briefing the individual had a casual and dismissive attitude about safety protocols. He had worked hundreds of jobs without a problem. "Errant breaker boy" was what we nicknamed the individual, was transferred out shortly after.
  • kmikemoo
    kmikemoo over 6 years ago
    Worst tool?  Your teeth.  They hold tools.  They strip wire.  They cut wire.  They hold small nuts.  They help cut tape and all sorts of packing material.  All at the cost of a little enamel and maybe some tooth material.
    Yeah... they're really poorly insulated though.  Got nailed twice in the same telephone project - in the ceiling.  I didn't fall, but MAN it really rings your bell.
    If it has to be a real tool... the Universal Socket.  It universally doesn't work on anything.
  • Gough Lui
    Gough Lui over 6 years ago in reply to dougw
    dougw  wrote:
    And then there is using your tongue to determine how much juice is left in a 9V battery...
    Yep - I did that from a young age and probably knocked out a few tastebuds that way. Worse still was that I followed my teachers and developed a habit of "cutting" sticky tape with my teeth. A mishap with some brown super-sticky packaging tape left my tongue and lips a little raw. Stripping wire (as mentioned earlier) is one of the favourites ... but I've also stripped wire with my fingernails as well.
    But yes, removing watches, jewellery, ties, rolling up sleeves, tying up hair, removing strobing sources of light (which could lead to misleading stroboscopic patterns which makes things look still even when they aren't) ... lots of good precautions to take near machinery.
    - Gough
    dougw over 6 years ago in reply to Gough Lui
    A finger can also be a "good" indicator that a wire is "live".
    Just because it is attached to a brain does not necessarily make it a "smart sensor" though.
    And then there is using your tongue to determine how much juice is left in a 9V battery...image
    dougw over 6 years ago in reply to phoenixcomm
    Good points - back in the day when I wore a tie every day, I always removed it before going into the machine shop.
  • ntewinkel
    ntewinkel over 6 years ago in reply to Gough Lui
    Ouch!
    I just learned yesterday (using your method) that the "100" for a heated 3d printer bed is, in fact, Celcius image
    You'd think we would learn by now, eh?
    • Vote Up +5 Vote Down
