Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11174 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
  • the-dubster
    the-dubster over 6 years ago in reply to genebren
    genebren We had various issues with one of the modules in the PTR1721 radio, it would pass all checks at repair/test and then fail when fitted to the next highest assembly (the radio chassis). The tolerances of the 3rd line test kit were looser than the actual radio could handle!!
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to ralphjy
    ralphjy Bend over and smile. image  I use to use them also in the AF to check engine blades for cracks.
  • phoenixcomm
    ralphjy they have no respect for wire-wrap BTW I do all of my prototyping that way.
  • the-dubster
    the-dubster over 6 years ago in reply to majanan
    Had a weird snag on the Tornado F3 RHWR (Radar homing warning receiver) System many years ago. The loom that ran along the spine became our prime suspect, and after doing pin-to-pin checks for open circuits we had to release the aircraft back to squadron with the system 'Limited'.
    A month or so later it returned to the shed for the Major Maintenance, we passed on what we had done and suggested core-to-screen checks were carried out for shorts. Lo and behold, there was one cable in the loom that was exhibiting this very issue.
    Out came the Time Domain Reflectometer (screen and earth cable works very similarly to coax to a TDR) and we found the exact spot the loom was damaged. (You can see transitions thru bulkhead connectors on the TDR trace, and follow them on the wiring diagrams).
    The loom was popped open and the culprit found - a beautiful slice through the outer insulation, the screen and inner insulation, with a few stray strands of screen touching the inner core . . . . . .
    The culprit? The loom is knotted with lacing cord every few inches, and some deft folks were able to invert a scalpel blade between the individual wires in the loom and slice the lacing cord without causing damage.
    The muppet who had done this one however had decided to saw straight across the loom at 90 degrees - he cut the lacing cord, but that unfortunately wasn't all.
    We're right back to accidents (many) that I have had with scalpels, and your examples . . . . . . .scalpels are probably the most useful and, in equal measure, the worst tools to use for electronics . . . . . .
    • Vote Up +5 Vote Down
  • majanan
    majanan over 6 years ago
    For me it's got to be  the deadly scalpel... I will use one in a pickle when I forget or lose my wire strippers...
    I can't count the amount of small cuts I've given myself or the frustration at the inability to properly strip wires and cutting through wire insulation where I shouldn't that I have done with a scalpel.
    The worst case was when I blew all the fuses in my  parent's house by wiring up a wall socket with the smallest gash/cut, incredibly hard to see, on the live wire that touched the metal back box that it was all mounted within.
    Fortunately it was just the fuse box and an angry dad for messing it up rather than a fire but super frustrating to find the issue when we had wired about 10 sockets that day!!
    As an aside, I have messed up a fair few PCBs through hasty use of a scalpel :/
    genebren over 6 years ago in reply to ralphjy
    Wow, small world!  In the mid 70's I started in electronics doing a lot of ATE work across multiple systems, for military and avionics electronics.  I then moved into a more specialized corner of the ATE market, designing electronics/software for in-circuit testers for testing PCBs.  I saw a lot of junk out there, as well as some pretty cool stuff.  So many times it was necessary to widen the test limits so much (due to the drift/lack of accuracy) that even bad boards would pass.
  • ralphjy
    ralphjy over 6 years ago in reply to the-dubster
    Back in another lifetime I also worked on ATE for avionics.  That was back in the 70's when we were doing the first cruise missiles.  I was amazed that we actually got all that stuff to work image.  Even more amazing that we put a man on the moon.
    Of course, even nowadays things only "sort of" work most of the time image.
  • the-dubster
    the-dubster over 6 years ago in reply to ralphjy
    Aaahhhhh, wirewrapped terminals! You just gave me flashbacks!
    I had the dubious pleasure of using various bits of GPATE (general purpose ATE) back in my (thankfully infrequent) 'bay days' in the RAF . . . . . .
    Some of our kit took 4-5 hours to test the kit and 8 hours to get the damned thing working in the first place. The old 19" rack system for the old Tornado GR1/4 Flight Control boxes (Pitch & Lateral Computer) never got switched off once it was running properly . . . . .
    And then you had to reconfigure it for another box . . . . . .   image
    • Vote Up +6 Vote Down
  • ralphjy
    I've been enjoying reading all these stories.  There was a tool that I always hated using, probably not because it was the worst tool but because of the circumstances in which we had to use it.  Back in the good old days we used to build fairly complex ATE (automated test equipment) using massive wirewrapped backplanes.  There were the inevitable shorts or opens which were usually extremely difficult to find in the rats nest of wirewrapped connectors.  Our tool of choice was something called a borescope which was an illuminated optical tube about 18 inches long with an eyepiece on the end that allowed you to get a view down at the pins.  Because of the nature of the troubleshooting you had to be physically in the backplane and sometimes under it and much of the time the unit was powered up.  I remember a time when a dipped tantalum capacitor burst into flames while I was under the backplane and I ended up with a nasty bump on my head because of my reflex reaction.  I can still remember the vivid image of the orange flame bursting through the side of the capacitor!  Suffice to say that I hated using that tool.
    Nowadays, I use a similar tool - a USB inspection camera in much friendlier circumstances and it has the advantage of not having your face up next to the tool in case of surprises image.
    Here's a pic of my inspection cam.
    dougw over 6 years ago in reply to luislabmo
    That SS02 looks great - I want one. image
