Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11179 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
  • luislabmo
    luislabmo over 6 years ago in reply to dougw
    Hi Doug,
    I second to this but not all the small solder pumps are made equal. I think the Engineer SS-02 is the best one. It has a replaceable silicone tip so it won't melt and it will adapt better to whatever you try to desolder.
    Here is a nice comparison from the manufacturer's website:
    Luisimage
    • Vote Up +6 Vote Down
  • Fred27
    Fred27 over 6 years ago
    Some great stories and even a few good tips for tools! Thanks.
    All these stories about using a inappropriate tools for an electronics job reminded me of the flip side - using an electronics tools for a non-electronics job. I tried using my Yihua 898D+ hot air rework station in the kitchen, but I wouldn't recommend it. I will blow all the sugar off the top of your crème brûlée and make a right mess.
    • Vote Up +5 Vote Down
    dougw over 6 years ago in reply to smocksam
    I thought bigger would be better, but I find I use the smaller one far more often.
  • mahmood.hassan
    mahmood.hassan over 6 years ago in reply to smocksam
  • smocksam
    smocksam over 6 years ago
    That's not a solder sucker, this is a solder sucker! image
  • the-dubster
    the-dubster over 6 years ago in reply to industrialautonathan
    shabaz over 6 years ago in reply to Attila Tőkés
    It is possibly the solder sucking tool itself. With the tool I'm using, if I push down the plunger, I can feel the air draft caused by it from more than 30 cm away. With that, solder has little chance of not being sucked up, provided it is positioned ok, and the solder is fully melted. On the other hand, with a different manufacturer solder sucking tool, it is a lot more hit-and-miss.
    dougw over 6 years ago in reply to Attila Tőkés
    The solder sucker should cleanly suck all the solder in one try. To get this to happen, the suction tip needs to be very close to the molten solder - essentially touching, and almost no air gaps around the suction tip.
    The iron tip generally gets in the way of getting the suction tip to an optimal distance, so you need to remove the iron and quickly position the suction tip properly before triggering the suction and this needs to happen while the solder is still molten.
    Often you will need to add solder to the area before trying the suction process - this is to add thermal mass so the solder stays molten long enough to get the suction tip in place.
    It takes some practice to get a feel for how much solder is needed to stay molten and how hot your iron should be, and exactly how close the suction tip needs to be, and how fast you need to be to get a clean shot.
    It will help if your work-piece is securely held while you work the tools.
  • industrialautonathan
    industrialautonathan over 6 years ago
    In my experience, the worst tool to use for most electronics projects is a community college lab partner. The one I was issued handed me a VFD he had just wired up so I could inspect it before we plugged it in. While I was holding it in my hand, out in front of my face, he plugged the power cord in! Unfortunately, I hadn't had it long enough to notice he had wired 240v power into the output terminals and it exploded. Fortunately, I was wearing gloves and safety glasses.
  • TCPMeta
    TCPMeta over 6 years ago in reply to Attila Tőkés
    Solder Braid has flux in it already but I find by adding a bit more onto the onto it on the side you apply the heat from the Iron super charges it, it will let more solder pull through into the Braid/Wick. I figured this out in desperation when I had a weak iron trying to remove something that had Lead Free Solder.
    My Solder Station is a cheap Circuit Specialists STATION-60. I think it's a cheaper variant of the old Hakko 936 that you see floating around eBay. Some day I'll buy a real Hakko FX.
