Documents elf14 presents - The Test and Measurement Tool Bundle Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 26 Jan 2021 9:28 AM
  • Views 10593 views
  • Likes 20 likes
  • Comments 194 comments
The Test and Measurement Tool Bundle Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Test and Measurement Tool Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your first test or measurement tool?
Why that tool? How did it help you, what project did you use it on? Do you still have it in your collection or on your bench, or has it since been replaced?
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Handheld Digital OscilloscopeMulticomp Pro1Buy NowBuy Now
Handheld Digital MultimeterMulticomp Pro1Buy NowBuy Now
Humidity MeterMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 12 PIECEMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 10 PIECEMulticomp Pro1Buy NowBuy Now
Congratulations to the Winner!
nathandumont has been chosen, and they have managed to get in touch!
It would have been unfair to deny the prize due to technical problems, thank you to everyone for entering!
Terms and Conditions apply.
  • elf14 presents
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • giveaway
  • test and measurement tool bundle giveaway
  • ralphjy
    ralphjy over 5 years ago +12
    I remember when I was just starting in college I decided that I was building enough electronics that I needed a Volt-Ohm-Milliammeter (VOM) of my own and I bought a Knight Kit from Allied Electronics and…
    dubbie over 5 years ago +10
    When I started with electronics I was probably only 16 or 17 and managed for several years without any test equipment at all. Obviously, not much of my stuff worked as I had no method of finding faults…
    genebren over 5 years ago +10
    I was always in a hurry to grow up and get a 'real job'. I completed High School in three years and college in three years. While in High School, I spent nearly half of my time in the Electronics Lab …
  • neilk
    neilk over 5 years ago
    From the age of about 16 or 17, I somehow manged without any test equipment at all until I was given an ancient Avo meter. I used that until it died and I had to replace it.
    Sadly, I disposed of it many years ago..........there's only so much nostalgia that you can hang on to, especially after you have children!
    Neil
    • Vote Up +5 Vote Down
    When I started with electronics I was probably only 16 or 17 and managed for several years without any test equipment at all. Obviously, not much of my stuff worked as I had no method of finding faults. Eventually while at University I decided to buy my own mutlimeter, a TMK Model 500. I have no idea why I purchased that specific meter. I think I really wanted an Avo meter and just couldn't afford one.
    I paid £19.95 for it in 1977 - which is the equivalent of £112 now, probably at least a weeks wages back then. I even had to order it, put down a deposit and collect it later. Can you imagine doing that now! I know all this as I still have the invoice.
    I'd like to be able to say that it still works but it doesn't really. The mechanical switch part for changing ranges has changed in some way and the contacts are unreliable. It measures voltages mostly OK. I have almost thrown it away on several occasions but in the end I just could not do it. Just too sentimental I guess.
    Dubbie
    • Vote Up +10 Vote Down
  • koudelad
    koudelad over 5 years ago
    I can't find a photo of it and I don't have it for years, but my first measurement tool was a €20 Uni-t DMM. I was at high school, I played with resistors, LEDs, transistors, voltage regulators and an 8-bit PIC16F876. I remember I had to save my pocket money for about 6 months to buy it. And after I bought it, I measured everything - all AAA / AA / 9V batteries voltages, all resistors before using them, all transistors (it had the h21e transistor tester) and also mains voltage. It was mind-blowing for me to see the values of all quantities I could only calculate or estimate before.
    I believe a good DMM is still a must-have tool for hobbyists and professionals.
  • ralphjy
    I remember when I was just starting in college I decided that I was building enough electronics that I needed a Volt-Ohm-Milliammeter (VOM) of my own and I bought a Knight Kit from Allied Electronics and built it.  It was a Model KG-684.  I think the first thing that I used it on was a remote slave flash unit that I built for my older brother who was into photography.  It served me well for decades and I still use it occasionally.  It's a little worse for wear with nicks, scratches and a crack in the case from when it got dropped.  I built all kinds of stuff back then.  I remember using the VOM to figure out the hookup on a capacitive discharge ignition unit that I built for my 1972 Toyota Celica.  Those were the good old days.....      It has long since been replaced with various DMMs.
    • Vote Up +12 Vote Down
