Documents elf14 presents - Circuit Assembly Tools Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 15 Jan 2021 11:21 AM
  • Views 9277 views
  • Likes 20 likes
  • Comments 140 comments
The Circuit Assembly Tools Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Circuit Assembly Tools Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your best electronics fix or repair?
What 'thing' did you figure out in a project or design, or repair that saved the day?
Tell us your good stories, or if you really don't have any, your best recovered disasters!
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
Register to Enter Now!
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM1Buy NowBuy Now
Wire Kit, Jumper, Copper, 0.6 mm Diameter, 350 PieceMCM1Buy NowBuy Now
Anti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator ClipMulticomp1Buy NowBuy Now
Single Channel Soldering Rework Station, 230V, 150WMulticomp Pro1Buy NowBuy Now
Solder Paste Squeege, Synthetic No Clean, PVCChip Quik1Buy NowBuy Now
Solder Paste, Synthetic No Clean, 183 °C, 63, 37 Sn, Pb, 15GChip Quik1Buy NowBuy Now
Solder Flux, Rosin, Soldering, Pen Applicator, 10 ml, 9.3 gMulticomp1Buy NowBuy Now
element14 presents Prototyping BreadBoardn/a1
Congratulations to the Winner!
davegsm82 has been chosen, and they have 7 days to respond to the message sent to them!
If you do not respond within 7 days, I will have to choose another winner!
Terms and Conditions apply.
  • elf14 presents
  • circuit assembly tools
  • circuit assembly tools giveaway
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • magikben
    magikben over 5 years ago +11
    When I was an engineering co-op in college I had a job working with the standby power group of a Cummins distributor. We had a big job putting a 1MW genset in a data center. Awesome unit with a quad turbo…
  • koudelad
    koudelad over 5 years ago +10
    My best electronics repair was a CNG boiler. Long story short: just before the freezing winter, my friend had a control board of a CNG boiler failure. It heated water and all the rooms. He was offered…
  • davegsm82
    davegsm82 over 5 years ago +10
    Just wanted to put this up and say thanks to the folks at element14, I received the prize from the competition and just wanted to put up this pic. The soldering station is amazing, and by happy coincidence…
  • hugohu
    hugohu over 5 years ago in reply to davegsm82
    Congrats!!!!
  • davegsm82
    The soldering station is amazing, and by happy coincidence some of the bits were out of stock so I was able to get select some spare tips up to the value of the items out of stock image
    Looks like now I'll have to clear a path to the bench in the workshop so I can actually get to work with it, instead of displaying it on the sofa! I really should because I have so many things to get on with.
    Thank you again Element14/Farnell image
    • Vote Up +10 Vote Down
  • redcharly
    redcharly over 5 years ago
    Congratulations davegsm82 I wish you have fun time with your new devices.  image
  • ralphjy
    ralphjy over 5 years ago
    Congratulations davegsm82!   Have fun with your new tools image.
  • davegsm82
    davegsm82 over 5 years ago in reply to dougw
    Thank you Douglas!
    dougw over 5 years ago
    Congratulations davegsm82 !
    dubbie over 5 years ago in reply to kamakazi13123
    Maddie,
    Ahhh, 286 systems, I remember them well.
    Dubbie
  • thareeq
    thareeq over 5 years ago
    This was fix on my own careless PCB designing. Two of us working on this project and this was the first time we were designing a PCB. We were using an stm32 and mc60 on the PCB. We used KiCAD for designing and he was working on Stm part and I am on MC60 part. We used txb0108 level shifter between them. We imported the footprint from snapeda or Mouser, dont really remember, since we were both working remotely some miscommunication happened and we end using a wrong pin numbers with smallest txbo108 package. Without knowing this we fabricated the PCB and assembled its components.
    As you could imagine the PCB didn't work and after some debugging I found out the issue that we had the wrong pin numbers. I tested all other parts everything is good except this issue.
    Since it is a very small package it was impossible to solder wires into the correct pins. I asked advice from some one who little bit more experienced than me on what to do. He said the same thing that since this was small package it is not possible to fix this and I should redo this.
    But for me that was no option, we spent a lot of money on this, I needed it to work. So then I realized I couldn't solder on one pin but I could definitely solder two pins together. I took closer on the txb0108 IC. I am only using 6 pins on this IC (tx, rx, gnd, Output_enable, VCCA, VCCB). I want these to its appropriate places, I noticed some of the pins I could short together without any issue. After some sitting and soldering some pins together (in 3 places) and scratching  some other pins out, I finally fixed it, made it work and saved our asses.
  • nathandumont
    nathandumont over 5 years ago
    My most dramatic fix was when I was doing A Level Chemistry. We had a PC in the lab which was meant to do some data logging. The teacher wasn't keen on it, he still insisted the BBC Master was better at data logging, but I knew him fairly well from working sound and lights in school productions. Starting the PC one morning it was sitting at the POST screen refusing to boot and ticking quietly to itself. Our home PC had failed a similar way a couple of months before so I had a good idea it was a "sticky" hard drive head. The head would park at shutdown and refuse to come out again at boot. I volunteered to take a look and walked up to the PC, got the rhythm of the ticking (the head trying to unpark) and then casually kicked it in the front panel in time with the next tick. Sure enough the BIOS scroll carried on and the OS started to boot. I went and sat back down. The teacher was momentarily speechless I had literally fixed his computer by kicking it!  Looking back I dread to think what would have happened if I'd kicked an expensive bit of school property and it hadn't fixed it.
  • warriorcelt
    warriorcelt over 5 years ago
    Many years ago, when the rocks were just cooling from their magma stage, I was moonlighting at a small community hospital.  My full time job had me doing silly things like jumping out of airplanes with 100lbs of medical gear on my back into some rather nasty areas.  This was a SMALL hospital with just 2 cardiac beds.  The closest trauma 1 was at least one and a half hours away.  We had the first bed occupied and a second in route.  The cardiac monitor system on the second bed would not power on and the facility had been waiting a week for the system tech to come work on it.  The cardiologist was ready to try and reroute the inbound patient when I took a look at the system and saw that the power "button" on the membrane control panel was considerably worn.  As the cardiologist started to have his own dysrhythmia, I pulled out my handy dandy knife and cut three sides of the membrane control and pulled it down.  Sure enough the contact was worn beyond belief.  With the cardiologist yelling at me and me telling him NOT to reroute the patient, I ran down to the snack machine and bought a pack of Wrigley's Big Red gum.  The look on his face as I came running back in the room and popping a piece of the gum in my mouth was rather hilarious.  He was beet red as I took the inner wrapper, cut it down and folded it into a small square with the foil out.  I then framed the foil with dermapore tape and taped the control membrane back in place and powered on the system.  We were able to stabilize the patient without having him potentially suffering any more damage with the added transport time.  The patient went home a week and a half later and the facility had the machine replaced.  That is how I saved a patient with a quick electronic repair using a gum wrapper.
