Documents elf14 presents - Circuit Assembly Tools Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 15 Jan 2021 11:21 AM
  • Views 9365 views
  • Likes 20 likes
  • Comments 140 comments
The Circuit Assembly Tools Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Circuit Assembly Tools Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your best electronics fix or repair?
What 'thing' did you figure out in a project or design, or repair that saved the day?
Tell us your good stories, or if you really don't have any, your best recovered disasters!
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
Register to Enter Now!
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM1Buy NowBuy Now
Wire Kit, Jumper, Copper, 0.6 mm Diameter, 350 PieceMCM1Buy NowBuy Now
Anti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator ClipMulticomp1Buy NowBuy Now
Single Channel Soldering Rework Station, 230V, 150WMulticomp Pro1Buy NowBuy Now
Solder Paste Squeege, Synthetic No Clean, PVCChip Quik1Buy NowBuy Now
Solder Paste, Synthetic No Clean, 183 °C, 63, 37 Sn, Pb, 15GChip Quik1Buy NowBuy Now
Solder Flux, Rosin, Soldering, Pen Applicator, 10 ml, 9.3 gMulticomp1Buy NowBuy Now
element14 presents Prototyping BreadBoardn/a1
Congratulations to the Winner!
davegsm82 has been chosen, and they have 7 days to respond to the message sent to them!
If you do not respond within 7 days, I will have to choose another winner!
Terms and Conditions apply.
  • elf14 presents
  • circuit assembly tools
  • circuit assembly tools giveaway
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • magikben
    magikben over 5 years ago +11
    When I was an engineering co-op in college I had a job working with the standby power group of a Cummins distributor. We had a big job putting a 1MW genset in a data center. Awesome unit with a quad turbo…
  • koudelad
    koudelad over 5 years ago +10
    My best electronics repair was a CNG boiler. Long story short: just before the freezing winter, my friend had a control board of a CNG boiler failure. It heated water and all the rooms. He was offered…
  • davegsm82
    davegsm82 over 5 years ago +10
    Just wanted to put this up and say thanks to the folks at element14, I received the prize from the competition and just wanted to put up this pic. The soldering station is amazing, and by happy coincidence…
  • magikben
    When I was an engineering co-op in college I had a job working with the standby power group of a Cummins distributor. We had a big job putting a 1MW genset in a data center. Awesome unit with a quad turbo, 50L, V16 diesel engine spinning the generator. We get a call from the project electricians explaining how there was a "goof" and one of their guys "accidentally" attached a 440v line to the low voltage (12v) annunciator wiring. The damage was limited to the annunciator board and swapping it out wasn't a huge deal but they are all custom built. We wouldn't get a custom unit in time for the contract deadline and missing the deadline would costs thousands of dollars each day until it was met. I looked at the old board and how the standard panels were and told my boss, "I can make the standard one work for us. Get me one." He trusted this co-op student with the task, had a new, non-custom panel delivered the next day and with a borrowed soldering iron I was able to salvage enough of the old board to replicate the customizations on the new board. This worked perfect and allowed us to meet the deadline with no penalties. It was eventually replaced with a newly built custom unit but I am positive mine would have worked just as well. When I left to go back to school I was presented with the award shown in the picture made from the panel I modified. While I felt the repair was kind of basic I saw how much it helped the people in my company and I am still proud every time I look at it.
    • Vote Up +11 Vote Down
  • jackkc7vlo
    jackkc7vlo over 5 years ago
    Way back in my freshman year in college (a long time ago), I had a friend who said she dropped her 13 inch TV and said it had strange static and noise when turned on.   This was back in the CRT days.  When I looked into it, I could see arcing in the high voltage flyback transformer.   Apparently it cracked when it was dropped.   I was able jam 2 plastic knifes between the crack and the outside casing blocking the arc.    I saw her years later and she told me it was still working!
    • Vote Up +5 Vote Down
  • kb3gkc
    kb3gkc over 5 years ago
    I work on tugboats and several years ago, we were getting ready to tow a barge and discovered that the levelwind for the winch would only move in one direction. Being the engineer, it was my job to fix it. The winch control panel is full of electronics. I pulled out a defective "module" for the levelwind control and replaced it with a spare. Problem solved in under 10 minutes and everyone was amazed at how I knew what to do. So that was really just parts swapping and not terribly impressive.
    My best electronic repair I think was I had an Astron 24 volt power supply that stopped working. Found a bad pass transistor and replaced it but it still wouldn't work. Finally tracked it down to a nearly undetectable broken trace on the regulator board that was hiding under the solder mask.
    One good lesson that I have learned in doing repairs, never assume anything.
    On the boats, coffee is king. Some of the guys are very particular about it. So knowing my talent for fixing all sorts of crazy things, they hand me a small coffee grinder. These things are basically disposable but when you're at sea and can't just run to the store for a new one, you better know how to repair stuff.
    The deckhand was grinding coffee when a bean jammed under the blades and it died. So I took it apart, replaced the hidden fuse and saved the day. LOL!
    I know it's a lame story.
  • tjfoth
    tjfoth over 5 years ago
    My best electronics fix or repair is the construction of my current HF antenna.  It is an inverted L and it works fabulous.
    What I learned was the value of doing antenna simulations in conjunction with real world evaluation... and the enjoyment of using something you studied, built, and worked so well.
    I've built lots of other antennas earlier on in my ham career, before things like antenna analyzer and simulation was available. The current state of the art makes it much more enjoyable.
  • jc1995
    jc1995 over 5 years ago
    My Job consists of repairing a lot of AV equipment and I would have to say that soldering a surface mount chip set on to a damaged Mixing console main board has to be the most interesting thing considering I had no hot air temperature controlled kit all I had was a big hot air gun with a on or off function and no way of protecting the rest of the components around. I must say I have not been anymore concerted about the almost £5,000 replacement price of the board if things were to go pear shaped.
  • spiralbrain
    spiralbrain over 5 years ago
    Here is how I revived an old PC hardware using an Arduino to emulate a PS2 keyboard.
    Fixed a faulty RAM
    And Made a PC tower using Leftover IC sticks,
    And Played Mario on TV
    This also got featured on Hackaday, Link to the Hack-build below:
    Resurrection of an old PC | The Turbaned Engineer's Blog (wordpress.com)
  • winzurf
    winzurf over 5 years ago
    My job allowed me to try out new technologies which meant sometimes I had solutions waiting for a problem - pretty important when delivery times from USA or Europe could be 6 months (to New Zealand - early 70s). As an experiment I designed a slow scan video capture circuit for IBM PC which used a single 8 bit shift register. Then New Zealand had a number of compressed natural gas bottle explosions (many cars were running on CNG at the time), and the problem was narrowed to gas bottles that were made of softer metal than was safe. A program was introduced to remove (from cars) and hardness test all bottles of a certain type - this was done by pressing a small ball bearing into the metal with a known force, then measuring the diameter of the indentation, too big and the bottle was failed.
    We created a jig to hold the bottle for testing, added a video camera to a microscope to view the indentation, and I modified my software to display the image on the computer screen with cursors that could be moved to measure the width. Put the whole thing together in a couple of days and it ran 24 hours/day for weeks until we had tested over 100,000 CNG bottles. Cost, 1 video camera, less than $1 for electronics.
  • invinciverm
    invinciverm over 5 years ago
    I am an Electronics engineering student and work on different circuits for prototyping specially different general purpose tools as current continuity detector, op amp based different circuits using 741IC and many more...
    I have already a soldering kit, I am just testing my luck if good then it's pretty good....
  • kmschmi
    kmschmi over 5 years ago
    My first real teardown and repair happened in the mid-70s when my father, an air force electrical technician brought home a reel to reel tape machine mounted in a 6 ft rack. He said if I can get it working I could use, which was a god send to me as I was in a garage band and all we had to record on was a mono cassette deck. I asked him where I should start, and he suggested the library. I picked up some basic electronics books at the public library and luckily the base library had a technical manual for a tape deck, not the same manufacturer, but was good enough to give me clues on what to look for. As I tore into the unit and would ask my dad questions he would always say it sounds like you’re on the right track, but why do you think so, so I would have to distill what I had read and tested and explained the reasoning to him. This went on for about a month and I ended up replacing some capacitors, internal fuses and re-soldered some loose wiring. Cleaned and adjusted the motors and heads and wired it up for left and right microphone inputs. I borrowed a couple of microphones from our school music department, connected my stereo and turned it on, sweet success. It actually worked! and sounded good. I used the deck for several years, transferred a lot of my records to tape so I could go for hours without having to bother with the record player. In my late twenties I finally found out why my dad didn’t give me much guidance. He was in military intelligence and the technician position was just a cover, he didn’t have a clue about what was wrong with it and got an education through my explanations.
    • Vote Up +7 Vote Down
  • aofarmakis
    aofarmakis over 5 years ago
    Best sort of "disaster" I can think of was when a buddy of mine made a Variable Power Supply from an old ATX power supply from an old computer he had lying around. He had just finished all the wiring etc and I remember he was about to load it up with a lamp if I recall correctly. Anyway, before he did, I asked to see his wiring because I was planning on building one of those myself. Luckily, I quickly spotted a hanging wire he had forgotten to isolate on the inside at the very back of it that would be shorting the chassis of the power supply, which if he had activated it could've potentially destroyed his device in the best case scenario.
