Documents elf14 presents - Circuit Assembly Tools Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 15 Jan 2021 11:21 AM
  • Views 9285 views
  • Likes 20 likes
  • Comments 140 comments
The Circuit Assembly Tools Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Circuit Assembly Tools Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your best electronics fix or repair?
What 'thing' did you figure out in a project or design, or repair that saved the day?
Tell us your good stories, or if you really don't have any, your best recovered disasters!
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
Register to Enter Now!
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM1Buy NowBuy Now
Wire Kit, Jumper, Copper, 0.6 mm Diameter, 350 PieceMCM1Buy NowBuy Now
Anti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator ClipMulticomp1Buy NowBuy Now
Single Channel Soldering Rework Station, 230V, 150WMulticomp Pro1Buy NowBuy Now
Solder Paste Squeege, Synthetic No Clean, PVCChip Quik1Buy NowBuy Now
Solder Paste, Synthetic No Clean, 183 °C, 63, 37 Sn, Pb, 15GChip Quik1Buy NowBuy Now
Solder Flux, Rosin, Soldering, Pen Applicator, 10 ml, 9.3 gMulticomp1Buy NowBuy Now
element14 presents Prototyping BreadBoardn/a1
Congratulations to the Winner!
davegsm82 has been chosen, and they have 7 days to respond to the message sent to them!
If you do not respond within 7 days, I will have to choose another winner!
Terms and Conditions apply.
  • elf14 presents
  • circuit assembly tools
  • circuit assembly tools giveaway
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • magikben
    magikben over 5 years ago +11
    When I was an engineering co-op in college I had a job working with the standby power group of a Cummins distributor. We had a big job putting a 1MW genset in a data center. Awesome unit with a quad turbo…
  • koudelad
    koudelad over 5 years ago +10
    My best electronics repair was a CNG boiler. Long story short: just before the freezing winter, my friend had a control board of a CNG boiler failure. It heated water and all the rooms. He was offered…
  • davegsm82
    davegsm82 over 5 years ago +10
    Just wanted to put this up and say thanks to the folks at element14, I received the prize from the competition and just wanted to put up this pic. The soldering station is amazing, and by happy coincidence…
  • barelyrunning
    barelyrunning over 5 years ago
    My Honda Prelude had a dash light come on for the 4ws. After testing the wiring, everything pointed towards the 4ws computer. So I cracked it open and had a look, there were a few dry solders, which I haphazardly reflowed with a regular soldering iron. Still works to this day.
    I'd love to win the soldering station, as I have had to repair a lot of things using a regular soldering iron, and melted the surrounding plastics due to the huge tip.
  • istihegyi
    istihegyi over 5 years ago
    This is a story where i was just a dumbstruck watcher, but it has to be said as it's proof of an incredible craftsmanship in one of my colleagues.
    We designed an embedded irrigation controller around the beaglebone black, and ordered a couple of fully assembled prototypes. The main controller was a TI ARM in BGA324 package. Somehow we managed to forget about the reset pin and couldn't reliably boot up from the eMMC chip which had a custom linux image.. we didn't even route that net!
    Then my colleague G. comes along... he examined the layout, bought a mechanical edge finder for his CNC mill,  and milled mounting holes for our PCB. He then screwed the PCb onto his platform, found the edge of the board, took a measurement in altium designer and guided the mill to that exact position, and drilled down a hole, exactly beside the reset ball of the controller, but without touching the IC itself.. this was a 6 layer board.
    So, after he had visual on the ball, he soldered a wrapping wire onto it, by heating the wrap wire with his soldering station, centered the wire in the hole so it doesn't short with any other nets or any of the two power planes.. and soldered the other end onto a superglued connector.
    He did this on three prototypes and all of them worked at first try. Insane. Should I win anything with this story, I will gladly pass it to him. Absolutely insane.
  • glennpj
    glennpj over 5 years ago
    I'm fairly new to repairs but have managed to fix a few things for local people free of charge, I'm a hobbyist not a business. Sone things i have mended include a vacuum cleaner (faulty on/off switch a Roberts radio (faulty power supply capacitor).
    Glenn
  • vivek5789
    vivek5789 over 5 years ago
    My best repair was 250 watt SMPS based on half halfbridge typology.
    Output voltage regulation was big challeng there was some PCB design related Issues, I had fixed that Issue and saved my day.
  • hugohu
    hugohu over 5 years ago in reply to johnsayre
    Damn. Congrats and nice job.
    I'd send you a better iron but I don't have a good iron either xD
  • kmikemoo
    kmikemoo over 5 years ago in reply to johnsayre
    johnsayre  Congratulations on saving the day!  Big Win, Super Dad!  Thanks for sharing.  Anytime any one of us can be the guy or gal a 6-year old thinks we are, that's a huge victory.
    Also. welcome to the community.  As you've already seen, there are lots of helpful folks here.  It's awesome.
  • johnsayre
    johnsayre over 5 years ago in reply to 14rhb
    Thanks for the assist! I think the problem was posting from my phone instead of my computer...but post is edited and my kid smiles upon you all!
  • 14rhb
    14rhb over 5 years ago in reply to johnsayre
    Hi John,
    Well done on fixing the car and cheering your son up - bet he'll remember forever the year "dad saved Christmas" image.
    If you need to ever add a photo it should be the 7th icon along as highlighted in red in my screenshot below:
  • johnsayre
    My story just happened today... our six-year-old added a last-minute request for an r/c car for Christmas, so we bought one from a dollar store as a stocking stuffer (do you see where this is going?). Well, you get what you pay for, because this particular car was dead on arrival. The kid's eyes lit up when he opened it, we popped in the batteries and then...nothing but a lit LED on the controller. The kid broke down in tears and I promised to try and fix it, in spite of being totally new to electronics. Today (Dec. 26) I disassembled it and found 5 broken solder joints which I managed to resolder with my cheap $10 soldering iron. To my amazement, when I put it all back together it actually worked! We now have a very happy kid and a rather proud dad.
    (Note: I took a photo of said happy kid and his new car, but can't figure out how to post it.)
    EDIT: Here's the photo of the Christmas miracle:
    • Vote Up +6 Vote Down
    dubbie over 5 years ago in reply to hadallen
    Nicholas,
    Any day with a raise is a good day.
    Dubbie
